alot of people are going to hate this.. but 400R fronts are ghey.....
i kno wot u mean! i think the same to much holes and bumps n lumps... plus heaps around!!
Thats why im after some opinions of something different
https://www.sau.com.au/forums/topic/155236-r33-bodykits/#findComment-2887057
Go trust frount bar i searched for agers and its the nicest bar around. Im only stuck with finding side skirts and a rear bar as i have gtr skirts and gtr pods but want a bigger and smoother skirt and rear bar. What do ppl think of the veilside skirt and rear bar as i think it would be a perfect kit
https://www.sau.com.au/forums/topic/155236-r33-bodykits/#findComment-2888750
these kits have all been done to death I guess......
I'm basically tired of looking at Trust bodykit.....that massive hole in the middle looks super gay
Uras kits on R33 are so over rated, everyone says it's so great but I got tired of looking at it from day one.
The only combo I like is a GTR front bar with a 400R skirt and Rear Bar topped off with 33 GTR rear wing but square wing's ok too.
if all that fails, I think the series 2 look is the most funky and best designed factory look out of all the GTSTs
https://www.sau.com.au/forums/topic/155236-r33-bodykits/#findComment-2891828
Series 2 are nice if it wasn't for those big twin light things they got going on. Besides that I like the type-m s1 bar when modified 'correctly', by that I mean cut out middle bit, with the cut out edges plastic welded and repainted with a GT-R style grill added for a bit more aggresion
https://www.sau.com.au/forums/topic/155236-r33-bodykits/#findComment-2892461
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
