Front tyres wear out very quick! Help...Please
ken
 Share
Just purchase my R33 GTS-T 2 months ago. At that time the front tyres are ok. And 2-3 weeks ago I check them again and they are just above the legal limit. Today I check them again. There are no thread on the outside of left side tyre. The right side tyre is better, but is under the legal limit.
The car come with Tein NA adjustable suspension (not height adustable) and tyres are 235/45R17 front, 255/20R17 rear.
Any comment?
Do you guys have any experience about this?
Can we get a correct alignment with the after market lowered suspension?
p.s. Only drive 3000km in this 2 months.
Thanks
Wheel alignment is required!
Having lowered suspension causes some -ve camber, ask them to adjust this a neutral a possible. They wont get it neutral but it shouldn't be too bad.
There are also camber kits avaliable to give better adjustment. Find the "whiteline" web site as they have these kits, JMS may also have 'em.
Tell the guys to keep the "toe" neutral. When a car has camber it wears the tyres from the inside. To get even wear across the tyre the alignment people adjust the "toe" in negatively. The problem with this is that it eats away at the tyres faster! In my opinion, better to have slight worn tyres on the inside (over time), than to have tyres going bold in a very short time.
My 2c
Alan
 Share
    • @Butters I can't tell you why but the bigger HKS step 2 cams improved low and mid end immensely. Turbos started spooling about 1k RPM less than before and the idle/vacuum was rock solid, it was an absolute thrill to drive, 3rd gear pulls hit 180kmh where previously only managed 160. Conversely, the milder poncoms in there now have a funky idle making it harder to get off the line, drives poorly in lower revs, laggy and makes less power/torque throughout. Feels better after I swapped the EBC but unless I put it on the Dyno again, I can't say how much better.
    • Hi Sydney kid   do you still selling spring and blistein shocks for Nissan 260rs? Air any suspension upgrades? Please advice     yudy
    • Cams are not needed at this power level, they will create lag. The cam gears are a good idea though.
    • @Murray_Calavera yeah, I guessed as much, cooler temps, more boost, less knock, more timing, hello power. Unfortunately not quite within reach ATM, could upgrade my whole fuel system to support but still wouldn't have E85 to run it 😂  Anyway, I changed cams again, 260/260 poncam B and everything else the same except an EBC upgrade. Now I must say I was quite disappointed with the result as it was like running stock cams (didn't try to dial them in as they're supposed to be optimum already) but after awhile I suspected my new EBC was underperforming not to mention difficult to use. I recently swapped back my old EBC and it drives much better now, boost comes on sooner, more stable, no spikes etc, feels all quicker and faster than with stock cams. Planning to fiddle with the cam gears and see what happens but maybe skip the Dyno as I intend to revert to the HKS cams cos they really made the car come alive; low and mid end was unbelievable and it just wanted to rev to the moon, finally knew what people were raving about, RB26 really loves revs. Anyway, Dyno 03 is quite disappointing, in Dyno 02 although peak power was less and trailed off at the top, the low and mid end improvement more than made up for it.
    • @Darrel It's so tempting to say e85 is borderline magic. It cools the intake charge, so if you're flirting with the edge of the turbos compressor map it helps dramatically cool down the hot air the turbos are pumping. It is very resistant to detonation so you can crank the timing, I don't really want to say you won't be knock limited anymore.... but you probably wont be knock limited anymore lol. I wouldn't be surprised if you made 20% more power swapping to e85 (provided you have the fuel system to support them, bigger injectors maybe bigger pump etc).
