Cruise To The Spit This Sunday 11/2
Great Day despite The Spit being shut and also a few no shows :D Picked up Drew along the way who drove all the way from NSW to chk out the QLD scene. Thanks for all who attended.
Might organise another one next Sunday when the Spit is definately open! Stay tuned...
Oh and almost forgot, we managed to recruit a new QLD member who joined us in his Patrol today but soon to be in a 33 :yes: Welcome and be sure to contact Karen SMR33 for the relevant forms and payment!
Pics coming soon.
Cheers,
Jon
  • Replies 76
Posted Images
Well the liners survived my first outing today. The more things change the more they stay the same. Cruisin hasnt changed much in 25 years. Meet, Hang, ride, Hang, ride, Hang. go home. Gotta love it.
Met some damn fine liners and saw some first class cars. Thanx for a great day guys and gals. Will definitely do it again.
yes welcome bro, i had a GR8 day, to bad for the kid that went up $38k ride at the trafic lights eh.... cause of the dame ambo. Look we really have to get more people in on this as it feels good to meet all the new crew face to face,and its good to see some chicks in skylines, just wish my chick would get one too.
is she single?
Wasn't she with dat guy that was in the car?
Good to see some nice girls driving skylines who actually stop and say hi, need more of em rather then the stuck up ones that drive past ignoring the 6 odd skylines parked on the side of the road. lol
Where did you guys end up meeting? i had a quick look at the spit, and went down to the broadwater carpark but i didnt see anyone. i must have just missed yous. anyone coming down this sunday?
nice pics by the way.
Edited by bsd-gtst
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
