  • Replies 48
optus is dodgey - some lady called up and told me that i should upgrade to the $49 cap with 'yes' time - but then the stupid ass didnt put me on the 'yes' time option - ended up getting a $300 bill, that optus didnt want to help me sort out (because apparently i heard the lady wrong and that it was my fault)...so then i had to pay another $88 to go on to the $49 cap with the 'yes' time option....asked if I can cancel the plan and go to a prepaid option, that will cost me $250 odd.....it was a no win situation for me. Probalby will go to prepaid at the end of this plan....
I have a 3 prepaid phone for work now - its pretty cool. $30 recharge = 150 free smses, and 150 mins worth of free calls to other 3 phones.....
optus was good once upon a time, with its 'yes' time and 'yes' weekend...but now its crap....
If you ever see the option of going to a "Corporate Contract" deal I say go for it.
Vodaphone with 14c/min to any phone (mobile or landline) with no flagfalls.
And 9cent SMS'es
6cents per 5mins to Vodaphone phones :D
Unfortunately vodaphone's coverage isn't as good as Optus outside the major areas (from what I've seen).
  • 3 months later...
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
