  • Replies 113
Just happened to stumble across this thread - better late than never though...
The silver 33 on the first page is my car and yes it's a genuine Blitz LM FMIC.
Admittedly, I've always thought my FMIC sat a little low, but I've never given it more thought as I personally don't mind the way it looks and as my car isn't particularly low, I vary rarely scrape the return pipe (only done it a couple of times when I wasn't thinking...very minor).
I did need to relocate the horn to accomodate the mounting bracket and the cooler is mounted directly to the mounting bracket, so I'm not sure how it's possible to mount it any higher (other than angling the bottom of the FMIC towards the rear of the car). Perhaps I was supplied with the incorrect mounting bracket...
Otherwise, my setup looked very similar to the pics posted by Ol Mate above.
here ya go
:) cheers mate, would you be able to get the same pic but from the front of the car looking up at the return pipe and the radiator support bar??sorry to be a pain, If you cant be bothered thats ok lol :)
The only pic i really need now is a pic of the front of the car with the bumper on, if you could post some up when yourve got it all finished that would be awsome.
Cheers
This is the exact reason i need some decent pics, some people say that yours is mounted wrong (no offence) and that theirs dosent sit anywere near as low as yours, then others say yours is mounted rite and looks just like theirs, so in a way im getting two different stories, which is making it very hard to decide if i should get one or not, hence why i need pics.:)
Edited by nizmo_freek
coolers were not meant to be this hard ey?
Lol :) i know what you mean, but when your paying $1080 just for a cooler you want to know exactlly what your buying before you buy it lol
Sorry, but I must be missing the issue....I've shown you and sent you pics of the kit fitted on 2 different R33's (mine and Justin's) and it is CLEARLY NOT below the front bar on either of them.
I think you're making your own decision harder than it has to be.
Nizmo Freek, it's simple...
Obviously the kit can be made to sit higher than the way it appears on my car. Dezz's pic above is a perfect example - don't ask me how he did it though (unless his mounting bracket is different to the one I received - I bought mine brand new 3 years ago, so perhaps the bracket has been revised, or more likely I've got the incorrect bracket or done something incorrect when installing).
Without going to the trouble of pulling my front bar off (don't ask, I'd love to help, but I won't do it), I think you've got about as much info as you're going to get to help with your decision.
If you're still worried about the return pipe being too low or you're considering substantially lowering your car, then perhaps you should consider a different FMIC.
Im not one of those people that just says "she'll be right mate", i would rather know exactlly what im buying, ive just had a look at my car to compare it with "Ol_Mate's" pics and it dosent look like it will sit below the bumper.
Maybe i am making this decision hard, but i would rather know what its going to look like before i buy it instead of just buying it without knowing.
The kit does come with a 33 and a 34 mounting bracket, the only way I can see that ECR033 could mount is any lower than mine or Justin's is if he used the R34 bracket, and in saying that I don't know for sure that using the 34 bracket would make it sit lower...I'm just saying thats 1 possibility.
Everything lines up, so I guess we can cross the wrong bracket off the list then...
I didn't do any bashing as such though - just fitted it straight on as is. Either that, or I stuffed up something somewhere (doubt it though, as again i'm guessing nothing would line up properly).
Regardless, it's done the job the way it is for the last 3 years - no reason to change anything now :D
I think the set up is this way it's because it is meant mainly for low mount turbos, instead of having the pipes circling all over the engine bay this method is better, however if you change into top mount, it'll be a........ headache...
with regards to the blitz logo, It was already on it when I purchase...
I'm not sure what to do atm, I'm going to change to forward facing plenum and topmount, the exit of the pipe went back to the left of the car.. which i think requires snake shaped pipings ><
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
    • The stock manifold is "mostly" divided. The divider actually has a notch cut out of it where it would meet the divider on a twin scroll housing. I have no idea why. But whatever the reason, it would cause some cross talk when used with a twin scroll housing. People do put twin scroll housings onto that manifold. But I'm of the opinion that proper twin scroll internal gating is...not really possible at this scale. You'd be throwing good effort (ie $$) after bad, when you really should be doing something else. Notwithstanding that.... I am not sure what the idea that you are floating has to do with the difference in comp cover position caused by the highflow using a shorter length core than the stock Hitachi one. Can you clarify what you meant?
    • Majority of regulars are > 30. We all act at least 50. Definitely not friendly as we're all grumpy. 😛
