put some r33 gtst or r32 gtr calipers and rotors on it, its definately needed if u do any spirited driving as the stock brakes are horrible and with automatic u cant use the gears to slow u down either :P
Brad
Any indication of how much this would cost to do?
Cheers, Al
here in japan i can get the calipers for around 140 for hte front
and rotors for around 300 new
Dude, don't forget that in Japan you probably have an abundance of places to get the parts from, with a lot more choice than us here in Australia, and I'm guessing you're quoting US Dollars, not Australian Dollars, so the prices are somewhat irrelevant to us...
Oh, and Kylie, I thought the front pads were DB1250's? Might have to take them down for cross-referencing when the time comes to change mine... Like Leetom said, if you can't take one off and take it with you when you go to buy some, take a piece of paper and trace around one of the pads and take that to the parts shop to check against.
Hey Al im unsure on costs sorry, i know the 32 gtr and 33 gtst calipers (both the same) are fairly cheap, around $400 for a front pair as a rough estimate and slotted 297mm rotors from DBA would be around $400 for the pair as well. i bought the 34 brembos and 330mm rotors so i dont know about the other calipers/rotors except that they definately bolt on :P
good luck and catch u guys on the cruise tommorow :)
I did mine recently and found that I had to crack the bleed plug to get the piston to move back so I could fit the new pads.
The other cars I have changed pads on did not need this, the fluid just back flowed into the reservior.
Other than that, it was an easy job, saved me about NZ$200. At my last service, they said that they needed doing, and they would do it for NZ$140 + skimming. My front discs did not need skimming so I did it myself.
im actually trying to see if i can mail stuff to you guys so i can pass on the japan price deals!
Hey Kylie
whenever you are changing pads and compressing the brake pistons in, just remember to get someone to watch the fluid level in the resevoir, as if it is full up and you do both without looking it can overflow. The level will rise as the calipers are pushed in. Brake fluid is not good for your engine bay!
Also you can use the tiptronic (to change down) in the S2 to slow the car, or in an S1 change down, into 2. It does help a bit.
So, does anyone have a complete set of Stagea calipers that they want to get rid of? I am looking for the 2 piston fronts and the rears that take the DB1144 pads (though will consider others). I am in Canberra, if that makes a difference.
Cheers,
Matt
Edited by Matty T
Not sure what you got, nor have I changed my pads before on my S2 Staj. But maybe the ABS has something to do with the above problems.??
I forgot to take pictures
I'm sorry, but if you want to remain a bonafide member of this forum you will have to go back and take pictures...and we dont care if it is raining...or snowing...pics or ban!!
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
