Nar must be another GTR i aint been driving i dont get my license back till next tuesday...ill come on the cruise depending when the next one is and thanks for the comment guys.Yeah its got full comp insurance and alarms imobilisers and relays etc... just need a club lock hehehe. and the 70 hrs or so a week is surely how i got it...dam cars....
Edited by GtrVspec
No offence, but can you tell us the price you payed....or atleast the price bracket.... :( , their some R33 S3 GTR on the forum - ON ITERNAL PRICE drop mode...so want to know how much they ACTUALLY change hands for ?
arghhh inbetween 35000- 45000 this was late last year i got it. i got it fairly cheap as it needed a clutch done so i haggled to get it down on price. the ones i was looking at in the 40 000 + had more work done to them.
My all time favorite GTR is a series 3 R33 in midnight purple. I am very jealous. And to answer someones question before about the type of cooler it looks like an apexi delta fin cooler.
Cheers
Chris
We are on the same page Alpha. R33gtr in midnight purple would put a bona on a jellyfish. :happy:
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
