Hi all, Just cleaning out the shed, Can post the smaller items if required or Pickup, Lismore, NSW.
Nissan Skyline GTR Master Cylinder brace R32 $90
Sold the car so no longer needed. Used to brace the cylinder against the strut tower to improve brake feel/reduce flex. Sort of a race mod really but is anodised blue and looks cool too. (-:
Nissan Skyline GTR Master Cylinder R32 $90
Was Removed from a crashed GTR (NOT crashed due to brake failure) as a replacment for mine but it turned out to be a leaking ABS unit... so since the car is now also sold i no longer need this.
Nissan Skyline GTR coil packs R32 X5 $60 or $15 each (4 left)
Car was upgraded to splitfire coils, one pack got lost somewhere so there are only 5 left, maybe good for a 4 cylinder coil upgrade? (for sr20 etc?)
2X airpods without filter elements, generic/no brand, $10 for both
Sony Xplod Head unit and Stacker + Cadence Equaliser, with wireing, connections, cables, brackets etc. $280 the lot. Was working perfectly when removed from a car prior to sale, new car had decent audio so i have not used it again. (from memory the stacker alone cost over $500 new... ><)
Just email me at [email protected], PM here, or call me on (02)66333131 (Martin, best after 6pm)
I think my prices are reasionable but i am open to offers.
Thanks for looking,
martin
Edited by mmarschall
just curious are 32gtr coils the same as series 1 gtst? both external ignitors? will the just fit in? ive got the 32gtr head but if i can keep the coils i got then will be alot easier
ben...
Hey, sorry, im not sure about gtst coils, i think they may be different, maybe someone can answer you question in a different section of the forums? tech stuff?
the brace bolts to the cylinder itself and existing holes in the strut tower which is just infront of the cylinder.
thanks for the interest,
martin
  • 4 weeks later...
Bump, and decided to sell these too:
2X willans harnesses removed from my R32gtr before compliance. $200 the pair (or make an offer)
  • 5 months later...
  • 6 months later...
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
