G'day people,
I'm having trouble with my aircon. When a/c is turned on via climate control amp, the compressor doesn't turn on. The only way a/c can be turned on is if terminals 5 and 3 from the a/c relay is bridged out. I'm not good with my electrics but i have the following info that may help fing what the problem is.
with ignition left off: 0Volts in all terminals 1,2,3,5
terminals 1,2,3 are 0 ohms. 5th terminal has around 12.5 ohms varying
with ignition turned to ON: 0 volts in terminals 1 and 3, 11.5 volts in terminal 2, 11.4 in terminal 5
terminals 1,2,5 are o ohms. terminal 3 has .88 ohms.
i hope this helps. Cheers :sorcerer:
https://www.sau.com.au/forums/topic/155956-r32-gtr-aircon-problem/
Yeah, the air comes out cold. I've checked all fuses. I've also checked the diagnostic system for the a/c amp but it only came up with the sun sensor, only because i did it in the shade. I think it may be a problem with the a/c amp or somewhere in the wiring harness, but too much wiring confuses the hell outta me. I've checked the wiring diagram for the a/c in the repair manual under HA-3. If anyone has that diagram and could roughly point out where there may be a bad connection, they are bloody legendary.
Id say its low on gas. Low enough to not engage the clutch on the compressor but still just enough to get the air cool.
So get the system leak tested, repaired, and regassed.
Edited by Godzilla32
Id be doing the same.
Get it checked out properly. With a set of guages on the system the problem can be isolated in seconds.
If its the wiring issue then obviously you will be looking at the relay switching circuit which is not overly complicated.
Having a similar problem with mine can bridge the relay and compressor kicks in cold an lovely ran for an hour or so like this then poped the fuse. Checked out the compressor coil pin 5 on the relay in the manual drawing mentioned earlier measures 3.5 Ohms as per the manual (the 12.5 ohms ed is seeing would suggest the coil clutch to me). Looking at said drawing the only thing that can stop the signal from the ECCS control unit is the dual pressure switch. Was wondering if anyone knows if the dual pressure switch will stop the compressor switching on if pressure is to high or only if its to low. R134 gas has much higher head pressure than r12 (the original gas) and if its still the original switch this may be the problem or part of it.
My mate tested the pressure switch and he said it was fine. I think it may be a problem with the a/c amplifier. My mechanic friend was crossing over wires from the fan relay to the a/c relay. I dont know why he did that but must have fried it. The a/c used to work before he did this. He was trying to find out why my thermo fan wouldn't turn on.
  • 2 months later...
So you have checked you don't have a dud sensor?
Throw it in to diag mode and have a look at the temperature values from the 4 sensors or what ever it is.
I had a dud cabin air inlet temp sensor, constantly reading -30degree's.. Obviously it would refuse to engage the aircon's compressor as it was too damn cold. lol
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
