i feel like my skyline is losing power (its nonturbo so it doesnt have much in the first place lol), how can i tell if im right? what are some signs i can look for or listen for?
i tried gunning it pedal to the metal, didnt even spin the wheels... i was like wtf, i flat foot it and it just feels sluggish, doesnt make any funny noises, wat can i do to get the power back?
all i can think of is, clean the airfilter or replace it? any other suggestions, i service it every 6 months at mobil
but i duno man help me out thanks fellaz.
https://www.sau.com.au/forums/topic/156391-signs-your-engine-is-losing-power/
I wouldnt expect an NA 33 to spin the wheels during in gear acceleration (straight line). Unless its wet, in 1st or 2nd.
They are not a fast/powerful car. A commodore/falcon has more power. Maybe you are just getting used to it.
Fuel filter, air filter, check for flow through the cat (may be blocked) or any exhaust/intake restrictions. AFM clean also.
Get it compression tested, Get it seviced and check all filters, Oil filters, air filter etc etc.. Make sure no obstructions in exhaust i.e dints, cuts bumps and if that all fails take it to a mechanic and ask him to spin it up .. if he thinks it drives like shit get him to find the issue
each to their own but i wouldn't be too concerned about it, what id do would be put up with it and save some coin until you can replace it with a DET. if you dont want to do that then it could be a number of things...you also have to face the facts that its a 1400odd kilo car with a na 2.5lt in it, its not meant to be a fast car.
thanks fellas, i know its not a powerful car but im on my p's, 2 more years til im allowed to drive turbo, so i have plenty of time to save up... so excited. dw i aint gona do nothing stupid, i know to many people that have and are lucky to be alive. fun is for the track, main roads are for going from a to b.
Alright then "useful" not "usefull"
And you didn't even bother giving the lesson.
Speaking of said lesson. Are you sure you should be giving it? as you did not use a capital letter for the start of your sentance.
There is no need to get so anal about spelling on a car forum. Grow up.
Ha!
I'm not the one who is about to burst into tears..
Edited by Driver
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
