Have a GTR with hks 2530's & Tomei cams(unsure of specs) & bleed valve.
Doesnt come on full boost until about 6KRPM which isnt too bad pritty useable but had a look what other pple get with the same turbo's & seems 5KRPM is where they are hitting full boost?
Now i know the bleed valve is going to make it laggier but by how much? surely not 5-1000RPM?
Have checked all my vac lines etc there are lots of extra crap i need to cut-out but there are no leaks, is there anything else i should check?
https://www.sau.com.au/forums/topic/156452-laggy-gtr/
Like you say a bleed valve doesn't help, but it shouldn't make that much difference.
First suspect is the extra crap on the vacuum lines. Plug it/pinch it off and or remove it - then have another check.
Other things are:
Your ignition timing.
Your fuelling.
That the waste gates are closing properly.
Cam timing.
https://www.sau.com.au/forums/topic/156452-laggy-gtr/#findComment-2907499
turbos got adjustable actuators on them too?
probably not done up tight enough
I had the same problem with my 2530 on my rb20
wind in the bleed valve and adjust boost via the actuators you should need vice grips and two hands to put
the rod back on to the flap section
https://www.sau.com.au/forums/topic/156452-laggy-gtr/#findComment-2910395
Engine is fine, just been built & makes good power.
Cheers for that ill check a few things out, allready buggered around with two ebc's so will be leaving the bleed'r in there for another month or so until i buy a brand newy...its not really that bad just everyone talking about their responsive 2530's & im missing out! :sorcerer: . Good point on the actulators ill suss them out :happy:
https://www.sau.com.au/forums/topic/156452-laggy-gtr/#findComment-2910908
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
