I am pretty sure that the R33 GTR wheels (forged BBS) have the right offsets +35 for the stagea, and are a straight swap. Not sure about other standard type rims though, although I would assume that they have a similar offset too.
I run 17x8" +35 rims on my S2. the fronts are inside the guards by about half an inch,the rears by about a 1/4". the car is lowered with coilovers,and has castor rods up front,and camber arms in the rear,set to 1.25deg neg.
I test fitted some R33 GTR wheels (17x9" +30) back when I still had std suspension and they were outside the rear guards by about half an inch. maybe with excessive rear camber on the rear and some flaring they'd fit under,but not with std gear.
as long as you don't go crazy,and get equal widths front and rear,I doubt you'll have any dramas.
Justin...
Yep, the R33 GTR wheels fit, SydneyKid has a set on his Stagea and it looks HOT!!!
33 and 34 GTR factory wheels are 9 inch wide with a +30 offset
The rear fits but they are right on the body line and actually look too far out
Don't run wider than a 245 tyre on the rims and you will need to roll the rear guards to clear if you lower the car too far
I have 34 GTR wheels and I can say I am not totally happy with the fit.
If you find a set of aftermarket GTR wheels, most have a smaller offset like +20 to +10. These will sit out even further
Best stick with a 9 inch +35 (may need to check strut clearance of front) or go to a smaller width of 8 or 8.5.
The attached calculator is your best friend
http://marksink.com/tire_wheel_offset/offset.html
use a 215 40 tire on a 9 inch wide wheel.
if your going low
because that's safe working practice... :)
235's are stretched on a 9" rim,and you want to run even narrower? recommended width for a 9" rim is 255. 215 is a bit narrow. not everything the japanese do is a good idea.
Justin...
so your saying a 215 40 on a 17x9 is a bad idea?
then im screwed
thats a 17x9 with a 215/40 on it
its common pratice
Ive drifted on teh same setup multiple times on the 180
Please dont say somsething isnt safe when you really dont know if it is or not and just listen to other people
Fat tires on small rims looks retarded IMO.
and its not functional, it will handle like slop, youw ill have tons of sidewall flex while you turn, greatly diminishing the feeing of your car, and delayed inputs.
stretching not only looks good, but serves a performance advantage
a 255 looks like a ballon.
A 215/40R17 is outside of its manufacturer's recommended configuration on a 9" rim. All the cars that I see like that are either set that way for styling purposes or are drift cars e.g. hachis with 12" wide rims and stupid skinny tyres.
Not to mention the fact that if you are unlucky enough to clip a kerb, the tyre side wall hitting is a lot less damaging than the rim lip, and a lot less likely to dent the rim which can lead to a bead popping off unexpectedly. Not safe in any language.
I don't know huh? ok,keep thinking that if you like. who works on cars and also fits tyres for a living out of the two of us? I know I DO,and have the licenses to prove it. do you?
try finding ANY tyre fitter or manufacturer who will endorse what you've said. you'll be looking for a LONG time.
the japanese have a VERY loose grip on the concept of safety. the state of their circuits and the way they run events is enough evidence of that,even without looking at the cars themselves. just because it's common practice there,doesn't mean it's a good idea. they'll wake up eventually. that,or natural selection will do it for them.
I've run 235's on 9" wide rims before,and that's as far as I'd be willing to stretch a tyre. going down another 20mm is ludicrous,when the recommended width is 255.
and while we're at it,a 215/40/R17 is smaller than the original rolling diameter by a good half an inch,so your speedo is out as well.
and if your stagea is 4wd,you're slowly burning out you transfer case with the different front and rear rolling diameters of your staggered size setup.
way to go dude,you're a pioneer. keep a wrecker's number handy,you'll be neding one soon.
Justin...
Edited by fergo308
so learn how do drive and dont hit a curb?!?
ive never curbed a wheel since 16 and im 22
Justin...
well, a transfer case MIGHT burn out ya know, if i had a front driveshaft. but thats besides the point.
the fact is, its been proven a 215 on a 9 is no problem by many people
hell ive put a 215/45 on an 18x10.
no problems
we shall see , in the next three years i own my stagea (ill sell it in 2010) if i have a tire unseat a bead, then ill give someone my GTR brakes.
and a license only means that, a piece of paper.
I have done a lot of stuff, and because i don't do it as a profession (but instead i work on jet engines) i haven't needed to get the licenses.
And a manufacturer says stuff isnt safe becuase of idiots that do stupid things.
a 215 on a 9" wheels is hardly bad at all.
ive seen worse
like a 195 on a 9
thats crazy.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
