  • Replies 56
Keymake - is that the one floating round on the web? About hybrid install..
Did you guys have to trim the back of your indicators?
I've had to remake some brackets etc.
Must say that it isn't the most fun job. You feel like you're haking the sht out of your car hahah (Mostly all plastic though).
Might have to respray some of the bumper. Does anyone know if you can get the dark grey colour that is the darker tone on the 2 - tone silver and charcoal. The colour on the bottom part of the bumper and doors etc.
Not sure. I got sent this one from just jap. It's got Auto Bahn written on the top of the page.
Yeah I trimmed my indicators down as well. Refitting the front bar took more time than to fit the cooler.
As for the paint, Go to somewhere that mixes auto paint. Give them your paint code and they can put it in a pressure pack for you. Should cost about $35 for a 300ml pressure pack. See if you can find the paint code in the engine bay.
Anyways - the snorkel will need almost demolishing. What do others do besides running pods?
modify the snorkel. i couldnt find much direction anywhere besides running a pod in an enclosed box. making its not too bad. a few on here have done it. and ive posted this up before.
heres mine, im not a fan of pods either. seems to work fine:
Edited by jake33
Thanks Jake - nice pics. Will have to do that sometime. Did you add another feed since you have lost a bit of the inlet size?
Looks like I'm having to trim quite a bit of the fan blades - anybody had problems with the car running hot after doing this?
Also, it seems the top pipe just rests on the bonnet when you shut it. Can't really reposition it any better..these kits are a little dodge..not bad for the price though. Its resting on some insulation in one small area so should be ok I guess
hard to see by the pics but the inlet/mouth size hasnt changed that much.. a tiny bit smaller but thats all. no difference in temp, and feel absolutley no power loss. just running some plastic pipe up to the old stock cooler hole.. which obviously does nothing for CAI but somewhat.. is better than nothing..
i got my cooler installed at a workshop man. cant help ya. if ya got new clamps for the new FMIC then if there impossible to undo just cut the clamps off and you will have new clamps for the FMIC anyway.
They usually do ben because of the tight space you're working with (either hit the rad fan and have to trim it more, or hit the bonnet). Hitting the bonnet doens't necessary possess a problem. My strut brace touches the shield thing, and apart from marking it (putting an indentation in it, it deosn't do anything).
In regards to cutting the fan, i never noticed it running much hotter (not my car), but I have noticed that it CAN make wear the fan bearing wear quicker (since the fan is no longer balanced).
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
