Hi guys Im new to this site and I thought I would post a few pics up of my R32 drift pig. From experience I would have to say that a 32 is easier to slide than an s13 plus its a skyline haha. RB20's are the bomb. This car lived on limiter while I had it and nothing broke at all except for the stock turbo.
Heres a pic of the thing after me and some mates got got wasted and decided we were fullsick (sarcasm) graffiti artists haha $.post-35562-1171911349.jpg
I live in Townsville and I bought it from some dude down on the coast for $7k with a roadworthy (dunno how he got it cause every thing but the engine was stuffed).
List of mods:
Replaced stuffed shocks with less stuffed JIC coilovers
rb25 turbo (rear wheel on the stocker cried enough and tried to escape out the exhaust).
front mount
screamer pipe off the internal gate
set of 18 inch dishies (nicked of my soarer)
gtr drivers seat
nismo 2-way diff
new r32 gearbox
new exedy clutch
front and rear strut braces
tubosmart bleed valve set at 0.9 bar
made 162 rwkw on dyno dynamics dyno
The rest of the pics show it in various stages. Anyhow me and a mate from uni ended up giving it a backyard 2pac paintjob in that baby blue commodore colour and fitting a URAS kit.
Just sold it and I thought I'd be happy just cruising around in my soarer ( manual got a Trust T78-33d ) but Im having RB withdrawls so if anyone is selling a manual R33 gts25t for $11-13k pm me.
Edited by RBdrift
https://www.sau.com.au/forums/topic/157140-my-r32-slider/
markimak. yeah in hindsight it was pretty foolish. but the paint was shagged anyway so it didn't matter.
In the end it turned out OK and I had to sand all that crap off of it while prepping it for paint so I learnt a fair bit at the same time.
Dude if you think I would do that to a clean GTR like yours or something, you are mistaken :laugh:
Edited by RBdrift
https://www.sau.com.au/forums/topic/157140-my-r32-slider/#findComment-2921137
Dude if you think I would do that to a clean GTR like yours or something, you are mistaken :(
haha.. things ppl do when drunk..
anyway.. gl with ur R33.. :D
https://www.sau.com.au/forums/topic/157140-my-r32-slider/#findComment-2927028
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
