  • Replies 561
Posted Images
My move in time is also 4pm. What a crock. I didn't nominate that. I'll be there about 7:30-8.
Will anyone be able to help me get home to Sutherland after this or am I catching the train?
Garth, I'd use your plates except they wouldn't go with my whole black and white colour scheme. If you are coming to help anyway my front tyres are old and could use that silicone.
Nick, you can be my two helpers if you like so no probs getting in. Actually I heard they let pretty much anyone in to help on friday night. No charge.
hmm.my jack sucks.ftL.i will stay arround untill you come duncan.so you have 3 peeps there who can help.
Still no answer on the mini hi fi,do you want it or not.i can vaugely remember jess saying somthing allong the lines of she doesnt need it.corect me if i am wrong..so that people can hear what is going on on the tv.
Cool, thanks Adam.
Found out tonight that I've gotta be at the airport @ approx. 7.45pm, but I'll come and help then leave directly from Homebush. Got stickers, shirts, business cards, stubby holders, etc. packed, but I will have to leave it all there as I'm not sure how much luggage my cousin and her family have brought back from their trip. Can someone either keep the stuff with them, or (for anyone heading West to either Blacktown, the Hills or Parra, preferably) bring it when you leave so I can meet you and get it back off you?
If worst comes to worst, I will come back to Homebush to pick it up after dropping off the crew.
hmm that rules out my bunnings work lights they wont get to 2.2m (stop about 1.5 from memory). Do we need lights?
I have 2x SAU banners.
And 1 problem. Mark and my move in time is 8pm, and they said we will need to push the cars from the dock. Now that is fine for our car, 2 person job, but mark's car has certain challenges with rolling straight......
Can we have as many SAU people as possible wait around until we arrive (will try and get there a bit earlier)? We will probably need to get a couple of jacks under it, it will be slow and painful.
I will be there till the end and so will a few of the others...so there will be loads of peeps to help you push the car in :)
Yeah you can bring it and we will see how we can set it up :thumbsup:
so what time do we need to be there?
is there a number thats been floating around just incase? like lost n shet :thumbsup:
They should of sent you a email confirming your car entered and time to move in :P
Ok so what we need for tonite:
Table-Jess
TV-OZ
DVD Player-Trust33????
Hi Fi system-Trust33
Power leads (need a few just in case)-DIF/Jess/???
Power boards (need a couple)-DIF/Jess/???
Danger Tape-Adam33
Cones-Adam33
Flooring-Jess
Gaffa Tape and lots of it :P-Adam33/Jess
Double sided Tape-Malcolm
SAU Banners-Duncan
Business cards-Nick
SAU Display DVD-Andrew
Deck Chairs (for sat/sun)-Everyone
If I have forgotten anything please let me know or just bring it :domokun:
Ok I know I said I would not edit any more into the dvd put I could not help my self I will bring the latest copy tonight 35min xxx rated and has DRAG, DRIFT, and TRACK video also.
So I have added SOUND and if a HIFI can be hooked upto the DVD this would be good.
HELP!
I will need a lift back to Castle Hill tonight, can anyone help?
Also my wife has a dentist appointment at 9.30 on Sat morning, can some some fly by my house at Castle Hill to pick up me and my little boy on the way to Homebush?
Thanks in advance.
Look guys,
I can not approve leads on site.
I already have done 1 power lead which is about 15-20m long and 1 powerboard that has 6 outlets.
If I can get them tonight off you and you can do with the one I have already approved I can bring the others back on sat morning.
HELP!
Thanks in advance.
I should be able to pick you up in the morning, Paul. Will talk to you tonight about it. Don't forget the car seat (if required) for Bailey, I don't have one here at the moment.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
