hey guys
just want some opinions on how i can quiten my exhaust without having to change to standard so that it passes the epa test for noise pollution?
i've had it tested by 1 of their recommended repairers and it came in at 100dB. i put my modified silenceer in and it went down to 93dB. What else can i do to dull the sound a bit more?
cheers
daneil
https://www.sau.com.au/forums/topic/157266-exhaust-issues/
hi
im getting sent to the same pleace EPA for sound and polution and i will put in that 2mm plate in between the exaust,
but make sure that the 2mm plate is welded to the exaust if its not they will not pass it
(Weld it only in 4 corners so it is easy to take it of again)
(make sure that you havent got a aftermarket computer or chiped and that you havet got a boost controler)
glad i can help
Alex :P
https://www.sau.com.au/forums/topic/157266-exhaust-issues/#findComment-2920797
Note... putting a plate in is illegal.
Now carrying on... spend the money on a decent system and you wont have the problem :P
There are many brands that come virtually smack onto the noise restrictions.
Look at additional mufflers, its the only way :P
https://www.sau.com.au/forums/topic/157266-exhaust-issues/#findComment-2920826
Hey,
To shut it up and get it passed a drilled plate might work (either welded in, which is perfectly OK,
or removable-but-nobody-knows-its-there, which isn't).
The problem is that everything is supposed to be part of the exhaust (not removable). So your silencer (I'm
guessing you mean one of those things jammed in the tailpipe) is supposed to be welded in; and any plates
should be welded in. Anything removable will probably be removed before measuring...
The bad news is that when you remove the silencer and plate (you will, because the car will run like a busted ar5ehole),
you will probably get pinged again; this time, they will probably hit you with a big dollar fine straight away...
The good news is that if your pipework is 3" or smaller and you have stock cams/turbo it should be relatively easy to
legalise properly. A working cat, a centre straight-through resonator/muffler, and a rear straight-through muffler of
reasonable volume should allow you to get below the legal limit easily (and it will sound good too :laugh:).
If you have more lift/duration/overlap on the cams, or a bigger turbo, or bigger overall pipework you will need more muffling
to counterbalance that. 3.5" pipes are borderline but probably OK with stock cat/turbo/cams; for 4" pipes and aftermarket
turbo I had to use a rear muffler that was not straight-through.
It will be cheaper in the long run to do it right the first time... and no, you don't need to go back to stock to do it...
Regards,
Saliya
https://www.sau.com.au/forums/topic/157266-exhaust-issues/#findComment-2921295
i have a 3.5" kakimoto cat back. stock cat, front pipe and dump. turbo is running 7psi (used the solenoid grounding mod on it). the silencer sits right back into the exhaust almost invisible as it it a piece of pipe with a welded flat circle so its hard to see it.
thanks for the advice guys. think its just easier to put stocky zorst back on, pass the car and then just always run the silencer to stop cops picking on it all the time.
just 2 add, this will be my 3rd visit there, first 2 for pod and cooler conflicts.
https://www.sau.com.au/forums/topic/157266-exhaust-issues/#findComment-2921596
whe you get your car checked by the epa they have to use the decibelmeter 1 meter back on a 45 degree angle half a meter off the ground. So when you get your car tested rev the engine slowly (they'll test it at idle and at 65% of maximum engine revs I think) bring them up to the specified limit and then let it down slowly as this will make your exhaust sound quieter (jam your foot on and then let it straight off) every little bit counts.
I've also heard that putting on a droopy tip on your exhaust can also knock off 3-4db, and due to the nature and position of the test and meter I'd believe it as it would have to bounce the sound off the ground up into the meter rather than coming straight out at it.
Hope this helps
Cheers matt
https://www.sau.com.au/forums/topic/157266-exhaust-issues/#findComment-2923081
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
