hey guy's,
im thinking about this bottom end as a swap for my blown up vlt,
i have a rb25 and this bottom will be going on it,
does this sound ok?
forged pistons by cp or ross
new gudgoen pins clips moly ring's
block bored an honed & chemically cleaned
new welsh plugs,rod's shot peend closed an honed arp hight strength rod bolt's,
full acl race series bearing kit reco oil pump
crank linished, new seal's with a ratio of 9.1
what do you think this would be worth and how much would thisd handel?
thank's heaps
evan
https://www.sau.com.au/forums/topic/157373-ur-thoughts-on-this-bottom-end/
so that list is everything thats in the new bottom end you want to buy?
how many k's or new? sounds alright i guess, how much power you aiming to hit it with? you might wanna make sure everythings there before you buy
It isnt getting brought, it is getting swapped from a company, it has recept's and photo's of everything that will be going into the engine, as i have said i am swapping for a blown up vl turbo,
how much do you guy's think this be worth?
hey guy's,
does this sound ok?
thank's heaps
evan
if you were to build that bottom end, and you already owned the block,
you would get change out of $2000
if you pay any more then this you need to find a new workshop.
its a stock rebuild with forged pistons and thats it.
if your VLT motor has bits worth more then $1500 that are still usable, then dont do it
theres no mention of the crank being balanced to suit the new forged oversize pistons, so if that hasnt been done it will struggle to rev past 5k and will rattle itself to bits.
Why would you reco a oil pump when a brand new N1 is only $400
sounds dodgy..
Darren
reco oil pump? what!
cps yes,(they come with pins)
billet rods.
n1 pump with collar
9:1.
standard main and head bolts.
head clean up mild cams.
thats what i would concider a reasonable build without busting the bank
ok thank's for this, was going to swap tomorrow,
so really if im going to swap what should i ask for in this bottom end?
an in the head i just basically want it rebuilt with new cams springs an make sure all is good, befor even thinking about fuel and bigger turbo,
but this bottom end has me thinking he might be taking a lend of me and getting a cheap vlt.
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
