holy shit. thats not good at all man.
im just glad i dont hava any tools at arms reach in my car. cos if i did id be afraid id probaly stab someone through the kneecap with a blunt screwdriver. f**kers. i know how you feel. same thing happened to me on 1999 nye. my first car to. except they kicked in every panel; instead of me.welli was to busy trying to break one of there arms while the 3 otheres made short work of the body
get better dude. i feel like "lashing out" lets just hope we find them.
  • Replies 128
ah ok, I live on a street off warimoo. you know near toolang oval?
T04gtr is the only serious skyline in St Ives that i've seen (haven't seen yours yet). The rest are all banged up shitboxes/riceboxes owned by kids
yeah dave took me round wakie in his, and your righht its the only serious one in the burb, i used to leave live right near warrimoo oval.
i am a kid ( 19) and my drivers door is rooted from a semi trailer wheel
Shit Mike, sorry to hear.. thats pretty harsh..
cheers im heaps proud that 1) i didnt go into shock until i got to the hospital lol and 2) that i didnt cry hahahahaha
Yeah there has been lots of this crap around the Northern Beaches/ North Shore. It is getting worse too. Mate of mine got jumped outside Mona Vale hotel, one of the guys held him by the hair and the other dude layed into him. He was literally everyones best mate and had no bad bones in his whole body. He got ko'ed and ends up getting a metal plate in his head from a broken eye socket. We know who did it, and this guy now has eyes in the back of his head.
Mike you will find out who these guys are eventually and then it is up to you to either go to the cops or PM a few of us North Shore/ Beaches guys and do some vigilante justice :(
So do you guys all live around teh north shore?
st ives man, yeah we are local, plus i have a house in mona to. i found out who they are, and yes vigilante justice my be in order.
can't go to cops as i threw first punch, i wanted try and phsyc them out by taking them on instead of running,
hahah i was having a conversation with my friend the other day about this. I was asking if you were in the situation where you know it's going to end up brawling, would you throw the first bunch just for the hell of it?
did a conversation take place? or did they juts stop you and had that "i want your car look' written all over the facec?
they said give me your keys and i said no and punched
We should organise a north shore meet up. I have been meaning to sign up to SAU NSW for about 6 months now!
BTW nice work on getting in first!!
Edited by Chris_R33GTSt
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
