Hi. Ive just taken off a r32 actuator on my r33 turbo and replaced it with a stock r33 actuator.
Now theres a loud ticking noise coming from the rear turbo housing. It looks like the wastegate flap is too close to the rear housing.
Can anyone tell me why this has happened?
What was done to fit the r32 item? or was it a straight swap?
Im assuming my turbo wont be liking this too much...
Thanks :wacko::D
Edit: also the car is really slugish now. And doesnt come on boost til about 3000rpm!!!
Edited by 33SOM
https://www.sau.com.au/forums/topic/157987-r32-actuator-on-r33-turbo/
I checked both actuators compared to each other next to each other. They were identical in physical dimensions (otherwise I wouldn't have been able to use it).
If you're running a boost controller, you'll have to retune the gain etc. Because it was tuned for the 32 actuator.
If you try just running the actuator to vac without any boost controller, it'll be the same boost build.
I've had many 32 actuators before, and they always boost the same as the r33 ones
scraping noise is very very odd.
All the actuator does, is open and close the flap. When the actuator isn't 'actuating' the flap is closed tight. There isn't any sideways movement possible really.
It's physically impossible for it to touch your turbo wheel.
When it's open, it's not anywhere near the turbo wheel.
Have a look inside the dump, like take it off, and see if the wheel is contacting the housing. The turbo might actually have become worn?
I think it may have something to with the tension the wastegate actuator imposes on the wastegate.
To little tension and the wastegate rattles around like you mentioned and this also means the wastegate is partially open which explains the delay in boost.
It really makes no sense how it happened when you swaped actuators which are phycially the same dimmensions though.
I had a similar problem when I swapped turbo's. The core of the new turbo was shorter than old one, which made the actuator rod too long. My solution was to weld in a cable tensioner, which works in the same way as the HKS adjustable actuators.
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
