Just looking into options for what brake pads to run in our Targa car.
Its a bit of a pain as we've had to downgrade the front brakes from brembo's to R32 GTR's in order to clear the standard wheels (16x6.5 s15 rims). Still running the brembo's on the rear (2 piston).
I don't know much about brake pads but the names Pagid, Hawk, SBS are the few mentioned.
Im not really sure what heat range is required for Tarmac rally, but one would assume you would want good initial bite etc etc
Anyway ive looked at Ferodo DS3000 and they look ok, has anyone used them?
What about Project MU or Nismo pads?
Just looking around as might be able to get sponsor to supply a set, depending on recommendations and availability.
I'm using the Project MU NC pads in R32 calipers and they work a treat. 0-800 degree rating, so work well from cold, and so far no fade after 5 laps.
I'd highly recommend them.
with a heat range like that do they take a bit to get up to operating temp or what?
We'r running Hawk Blacks in our car, i've got the paper for them at home that has the heat ranges on it.
Adam mention Hawk Blacks, but i know nothing about them. and you know what he says to me?
Navigators job, you find out (common response now).
Looking at the sheet i'm not sure if we have Blacks or HT10's
Blacks temp range is 100-900F
HT10's are 300-1300F
I'll find the box tomorrow and find what they are.
So is Adam just being lazy? He's done a fair bit of racing, so i thought he's know a good pad off the top of his head. Just get some bendex ultimates, you'll never get another job again :wave:
I think the NC are the street or "light trackwork" pad. I used to have them in my cef I believe they're rated up to 350degrees. Never had em fade significantly even under heavy usage (but not circuit abuse).
The 800 ones are titan's or HCs or something.
So is Adam just being lazy? He's done a fair bit of racing, so i thought he's know a good pad off the top of his head. Just get some bendex ultimates, you'll never get another job again :laugh:
Yeh pretty much, maybe i should just get a set of powermax or something :)
I reckon Blacks would be more likely.
I keep looking at these Ferodo DS3000's though.... someone must have used them!
Sorry, my bad. I have the Titan HC's.
Mr30: With a heat range from 0 it would indicate that they work from well cold, whereas if you see the range of the hawk blacks it starts at 300, indicating it needs a bit of temp to get them working well.
That's my understanding anyway :laugh:
Ferni uses DS3000's, or has in the past. He said they worked well, but chewed through rotors. Don't know how well they work from cold though.
Tim the only real problem you will find running with pads like the DS3000's, PAGIDS, HAWKS is that they tend to require a little more heat in them before they really start to bite hard.
Now this isn't really a problem on most of the Targa stages but there are a few that have some hard braking in the first couple of k's.
I know when i was looking at pads last time for the 32 to run on the track i was having alot of trouble with locking wheels with the PAGID's and also with the EBC's that i tried.
Have a talk to Benno and ask what he was running (he would also know what Perry was running) personally i would go EBC yellows as i have tried and liked them in the past :happy:
yeah i've used DS3000 along with most of the other GTR track guys in sauvic. They chew your rotors big time when cold, so don't daily drive, but otherwise they are good. Need a bit of heat in them to get them to bite hard which may be your only issue for tarmac rally stuff compared to circuit sprints...
Used SBS DC from after trying EBC for two years in the R32. Used Dual Carbon ones, same calipers, same disc, similar weight...
Tried DS3000/2500 in Evo, ran sbs at Rally Tas - horn
Holywood will love 'em.
TT
If you'd your willing to spend the dollars - Pagid RS42 (blue) is what you want (Competition Friction/V-Sport). Very very progressive feel, not hard on rotors, come on straight away even with serious ducting and perfect heat range for tarmac, particually considering you guys won't see the super long targa stages.
I used to circuit race the GTSt on Hawk Blacks, they were good but far too bitey for the road even if your running ABS. I've used the Pagids on my 200SX, GTST and GTR and they are simply awesome.
Edited by t01-100
Further to GMB the EBC yellows are too high in the heat range and you've got nothing for the first corner... add ducting and you've got nothing for two corners!
EBC red are too low and you'll melt them... have seen it!
Right on, I agree, the blue's are spot on on the std size rotor package. We used them on the Suby Sti that weighed 1850 kg with us in it, and only experienced slight fade on one stage....... Grasstree Hill on the way down.
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
