Hi All
I have decided to put my car up for sale. I'm looking for around $20,000 for it
Most details are below, though I'm sure to have forgotten bits and pieces.
1993 R32 GTS4 with RB26
Resprayed in hot house green
Debadged
Trust front bar (also comes also with R32 GTR front bar in white)
17” Advanti Stalker rims with 255/45/17 tyres all round
R32 GTR engine
Tomei metal head gasket
Tomei metal exhaust/intake gaskets
N1 oil pump
N1 water pump
700cc Sard injectors
PowerFC
High mounted plain bearing GT35R (from GCG turbos)
Tial External wastegate
Custom exhaust manifold with externally venting screamer pipe
Custom exhaust and intercooler piping
2 x RB20 AFMs
Bosch 044 Fuel pump
Brake Stopper
Nismo twin plate clutch
R32 GTR gearbox
Front drive shafts have been reconditioned
Using GTS4 diffs front and rear (better ratios)
Car has 170,000km on clock but new engine installed in Feb' of this year
Roughly 7,000km done since new engine installed
Just been serviced
Conversion work done @ Supertek Automotives in Perth
Car was tuned at Hyperdrive in Malaga – made 410rwhp @ 18psi
Ran 11.9 @ 118mph
Have dyno chart + drag slip
$20,000 ono
If interested please call James on 0402 14 14 38
or email me at [email protected]
Genuine buyers only please
https://www.sau.com.au/forums/topic/158161-r32-gts4-w-rb26-conversion/
    • Long time no random post about shit. So I went down this deep deep rabbit hole of battery storage for the home, ended up locking in a 41.9kWh Fox ESS EQ4800 with 9 units stacked. Battery uses Lithium Iron Phosphate, similar to what you find in those deep cycle boat/caravan batteries. And yes, why did I go with a cheapie brand and not like Synergy? simply because I don't plan to stay at this house for more than another 3~5 years.  The entire install, DC coupling (removal of existing invertor, connecting the current 6.6kW array direct to the battery invertor), new 8kW invertor is $6K all up (after all the rebates etc.). Going with this lot: https://www.aussiesolarbatteries.com.au/ It did seem a bit too good to be true, however seems like the Whirlpool community has vetted it and when it comes to this kind of stuff, they seem to be all over it: https://forums.whirlpool.net.au/thread/9pxj8482?p=38   I've requested for the battery to be installed outside, next to my meter board and not inside - rather have it combust and ignite outside lol.
    • In Vic it would be a defect regardless of whether or not you cut a hole in the sheetmetal for the return pipe. The rules in Vic are shitful, and are generally interpreted as you can "make 2 mods to the intake system". Putting an FFP and an FMI onto it will almost certainly be seen as some huge number of intake mods. You really need to speak to an engineer before doing this stuff in VIC.
    • planning a r34 rb25 de+t with some other work, rather just have it done in a shop due to space limitations any recommendations? I have most the parts already I seen online Moore Performance and DR Drift any advice appreciated thanks
    • I’ve read the previous posts so just looking for latest information on how people have dealt with front facing plenum is it a defect etc or didn’t pass roadworthy or was it not noticed? Have a r34 and deciding if I should make a hole on the driver side or not.  I know some people have said blitz return flow but I might get rid of the stock intake down the line for a plenum so I rather set up for that now plus I already have a standard Intercooler. Car is mainly stock  Thanks.
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
