  • Replies 41
Probably a little bit off topic, but it reminded me of the time i had to remove the harmonic balancer on my old Commodore V8, and no matter what i tried (Body weight leaning on the breaker bar, hitting it with a hammer, borrowing a compressor and rattle gun) the damned bolt wouldn't come off!!!
Even after many of my friends having countless frustrating hours trying to get this crank bolt off, one of my friends after staring at the car for quite some time, came up with the idea of getting the breaker bar, putting a piece of pipe onto it's handle to make it longer and give it more leverage and placing it underneath the chassis rail, whilst i turned the key on the starter motor, and voila!!! one crank bolt loosened by the torque of the engine's own starter motor!
keep this nifty trick in mind kids, it could have saved me many hours of grief!
  • 2 years later...
belt 1302820P25 - $82.25
water pump 2101070T25 - $97.06
Can anyone confirm these are the right parts for the RB20?
When I called the Nissan dealer, they said that is the right parts, but when 2 workshops (not just one) called them, they were both told they needed a different water pump, which is worth $386?! HUGE difference. Mechanic said that he knows the RB30 and RB25 are different (the bolt hole issue others have mentioned) but he isn't sure about RB20.
Thanks
Chris
the belt part number is the right one although mine had a diff part number on it for the one i got but it only cost $88
water pump i was also quoted $383 through nissan which i thought was crazy they must have quoted an rb26 pump or something
i done this change over last friday/sat aswell as turbo change all was reletivaly easy if you have the tools to do it
we used a steering wheel, pulley puller to get the harmonic balancer off
to undo the crank bolt put it in 5th gear and have someone stand on the brakes so the car wont move and have someone use a tention wrench to breaker bar to undo it mine came off fairly easy
total cost was $88 + carton of beer :P
Searched, and not found any concrete answers......
Can some one please tell me a definate part number (genuine, and/or non- genuine) for the R32 gts-t's RB20DET timing belt, and the water pump.
I want to be sure, so I dont have to pull it apart before I buy parts..
I have heard that the water pump is the same as the RB30 locally offered motor, but then I have heard that a bolt hole doesnt line up properly..
Where can I get a timing belt from, if not only the nissan dealer.. (I'm in Adelaide, southern suburbs) Tried motortraders, repco, sprint auto..no such luck..
Surely some of you R32 gtst owners have done the belt change yourselves? Or does everyone pay someone else to do it?
Any help is appreciated!
Steve
You don't need part numbers. Just write down your VIN number and walk into your local nissan dealer. They will give you the correct part for your vehicle. The RB25 belt should be the same as the RB20 belt but genuine is the best way to go for quality on this item. The VL water pump WILL fit your vehicle.
This is the reason I have brought this topic back. The problem is the Nissan dealer told me a $120 pump is the go, but told the 2 shops I rang that $380ish pump is the go. They are obviously different pumps. Seems the Nissan dealer isn't too sure.
I will try the Rb30 pump and see what happens
Go either the cheaper RB30 pump or the GTR N1 pump that has the anti-cavitation plate that increases flow and prevents cavitation at high rpm.
Thats the only difference between the pumps. From memory the R33 series 2 pumps are slightly different being one bolt hole is slightly aligned different. If thats the case then grab a repco Rb30e pump as they have provision for this.
  • 3 weeks later...
reason i asked coz i was hoping to buy all the parts need to do a timing belt, water pump, idler and tensioner and timing case seals in one visit to the garage.
no idea what numbers they are?
I can tell you that when I got mine done, mechanic used
- RB30 water pump
- Cam Belt - Whatever Nissan reccomended (it was genuine)
The seals I left up to the mechanic to chase...same with bearings. The bearings were not in stock at CBC, he ended up having to get to sydney (live in newcastle) to find someone that stocked them.
I plan to post up the part numbers, just I am never on the net at home...which is where the receipt is.
The RB30 water pump has the same bolt pattern and will bolt up. (Its the RB25 that has a different bolt and won't bolt up)
But does it have the same impeller?
If its different you may get cavatation at high rpm on RB20.
The RB30 revs to 6400rpm where as the RB20 revs to 8000rpm.
Just a thought, that the impeller may be different, haven't actually inspected a 20DET pump alongside the RB30 so i can't say.
The Repco RB30 pump has provision for the RB25 S2 boltup.
With regards to cavitation.. I wouldn't worry. If you are reving to 8000rpm or anywhere over 6000-6500rpm you will be getting caviation with the stock pump anyway.
For track work where high rpm 6000-6500rpm+ is used definitely look at the rb26 N1 water pump.
A prime example is Roy's engine temp differences with those few more rev's.
I've seen my RB20 pump next to the rb30 pump. No differences, same design, same fin angle etc.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
