Ok..
couple of months back i started a topic which was about a similar issue, where under 50%+ acceleration i'd be getting popping outta the exhaust and felt like someone was pulling on the handbreak.
But this time, no popping noise.. its just accelerates, and around 4krpm it just dies in the ass till it gets past then continues to accelerate.
last time a ECU reset solved the issue, I've recently installed a SAFC (after this issue started) its untuned, but no fuel adjustments have been made, would this be doing it?
anyway im going to try and get a quick dynognosis tomorrow when i pick the car back up =)
just wondering if anyone can point me in the right direction to save $$$ on dyno time.
any way to turn R&R off completely
thanks.
Edited by illusiVe
https://www.sau.com.au/forums/topic/158382-r34-gtt-think-its-rnr-now-dammit/
safc willl help as you will be able to alter the fueling around those cells that are going into rnr
but it will not eliminate it entirely , like all safc operations it will be a bit of a juggling match
remap/full ecu is your only true solution
My R34 gtt did the exactly the same thing even on the dyno it would drop out mid range and then pick back up.
Firstly do ou still have the factory turbo??? If you do then that is your problem (it has nouthing to do with the computer) The nylon inpellar probally has cracks in it or even chips off it.
fixed it..
stupid guys who worked on my car needed to get to the suspension and for some reason ripped my boost controller.. so it wasnt plugged in, and when the 12v came in it grounded the engine, causing loss of power.
rewired and problem gone... for now :O
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
