There's a few here in SA that have basically just been bolted on.
It appears ~20psi makes a shade over 300rwkw.
I'd assume the difference between 20psi making 340-380rwkw and 20psi making a shade over 300rwkw is nice exhaust manifolds, plenums and a decent set of cams.
yeah. thats what i rekon to. im making atm 307 awkw on a t04z on 20 pound.
to be honest id expect more. but a stock as a rock motor just with the nesasery suport mods. im guessing yeah cams etc etc.
A LOT of people with the usual gear are getting 370-420rwkw on PULP without even going to Meth :P
Thats just the usual mods and around 23-25psi or there abouts.
I reckon you have a good number of things to look at if a t04z is only making 300rwkw on 20psi. Its a good 50-70rwkw down on what it should be
I run the 0.81 AR T04Z with a built 2.7 engine, cams, 4in exhaust, HKS manifold and i make 450kw on 24psi, thats nearly 1.8 bar. and BTW how does the stocker engine respond to a monster turbo like the T04Z. and how do you keep the old girl alive, dont you have issues with blowby due to older piston rings??
if i hijack this topic my apoligies
well morgs and pretty much everyone else has cams at the least. and a built motor with forgies so abit of timing could help.
my motor is still going strong. 170pound across all 6. (apart fron some cool oil leaks lol.
i put it down to oil and oil temp. and a concervative tune. tuners get a litle scared when they find out its a 230k old donk hehe.
so penrite syn 5 or syn 10. two 25 row oil coolers and overfilled oil by 1 litre. (up to the hump on the stick) to stop oil surge.
I must say is there much variance between the garret and hks versions in overall powerout put nismoid
Not to the tune of 70rwkw i dont believe so.
A few GTR's have been using Garrett t04z's here for a while and those are what im going off.
Not the HKS versions
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
