Hi all, i'm wondering if an offset of +35 will work on a GTR32. I dont really care how they look, im just concerned about how they perform on the track. And wot rim width is the best fit for 235/45/17 and 255/40/17 tyres? Will the performance of a GTR will affected in a negative way on the track with mismatched tyres front n rear, say 235/45/17 front and 255/40/17 rear? Any input will be greatly appreciated.
Cheers, Jyo.
Cheers, Jyo.
ATTESA doesn't like different diameter tyres, wears out the clutch pack something fierce.
GTR's tend to understeer, so using smaller tyres on the front is not a good idea
Over 60% of the weight of a GTR is on the front wheels, so using smaller tyres on the front is not a good idea.
Over 75% of the initial braking effort of a GTR comes from the front brakes, so using smaller tyres on the front is not a good idea.
:no: cheers :down:
why you would go to rims narrower than the ones the car was made with standard is beyond me. plenty of people are giving you advice, but you don't seem to want it?
I'll say it loud:
just buy the right/suitable wheels for your car!! do not stuff around with the wrong size/offset and spacers etc. it's a waste of time when you have the opportunity to save that hassle and just buy the correct fkn wheels straight up
standard wheels are 16X8 +30 so going to 17X7.5 is a dumb idea. no doubt about it. going to 17X9 +20 is a good idea. even 17X9+30 is a good idea. 17X8 +35 is NOT a good idea. yes it will work. your call will still roll along but you are going backwards from what your car had from the factory.
but the rims are narrower than stock. and 1.5 inches narrower than the most common 32 size (17X9). so yeah they will give more track than a stock rim but I don't understand why you'd want a narrower rim? yes a 0 offset will give more track than say a +20 offset (comparing rims of the same width) but putting a 235 on a 7.5 is not what I'd reccomend. I'd use a 235 on a 9 inch rim. sorry if I seem a little blunt but it seems to me like you are trying to re-invent the wheel for no good reason? (pun intended).
Yeah i get it, i was just thinking that +0 offset would give a wider track width? Think i got it wrong the other way..
what!! lol. vip stylzzzz. if you can find somwhere that pumpes guards to fit them let me know kaythanx :P
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
