hey!!! (ive made this topic everywhere.. but i shouldve done it here coz of the head im using)
bloody hell had to remake another account because i forgot my username, but hey I own a vl calais turbo and im just about to put a rb26/30 into my car..
the motor is out at the moment (i bought it off someone else who also had a vl) and just before i put it in my car i need to know what to do....
previously the engine was running off a microtech ltx12s (or lt12s if its the same shit whatever lol) and the car is still in its run in tune, at 10psi.
so having said this i could get the ecu off the guy aswell, and plug his into my car and away i'd be.
he also has a decent coil setup. but id probably give him my motec m4 and i'd pay less for the engine or watever ("cash adjustment")
now my dilemma.
im really confused and i have nfi what to do with my Motec m4 (which i still own)... it sez on their webpages etc that it can run upto 4 ignition drivers? then people said what u do is batch them or whatever..... but it wont be as good as the lt12s coil setup or whatever...blah blah
well this is what ive been told so far -
you can run a Motec 'ignition expander' (runs up to 8 coils) and use batch or semi seq fire for inj, no probs
Or if you want / like CDI ignitions, use the motec CDI-8 module, easy as. both of these interface directly with the M4 ecu.
and then..
"As trev and shazza said, if you dont wanna run the expander, just run wasted spark instead of sequential, with 3 Bosch coil packs and you'll have an ignition output spare.
I dont know who told you that batching them will make idle bad, but its totally not true if its tuned correctly. It just means that the coil fires during the power cycle of two cylinders, rather than just one"
i am soooo confused and dont know what to do ay.
all i know is i gotta buy atleast an "ignition expander" for 330bux or i could pay nearly 2grand for some CDI bs... which seems shithouse coz thats too much.
what do yas reckon is my best option.. go for the ecu which is good enough and is aleady tuned etc (microtech) or go the motec way???????
big thx.
ps - dont tell me to speak to my tuner lol, i will but its a public holiday on monday, so they wont be open and i NEED TO KNOW WHAT TO DO ASAP!!!!!
Edited by gnki'vlct
https://www.sau.com.au/forums/topic/158999-motec-m4-multiple-coils/
I would get a set of EL falcon ignition coils and run wastespark, there is no problem with wastespark, as heaps of factory and high performance cars run it. Set your dwell time to 4ms. If down the track you find that you need more spark grunt, you can easily fit a 4 channel cdi unit($600)and the coil block which is quite neat is about $120 brand new from ford. The coils even have the cylinder numbers already marked on it to make it easy to hook up the coils to the spark plugs.
Just to clear a few things up wasted spark fires 1 cylinder on the compression stroke the other on the exhuast stroke.
4ms of dwell at 13v is a fair amount I would probably run around 2.5ms - so you dont burn coils out.
Wasted spark is not what I would be worried about. Its the batch firing of the injectors that I would be most concerned about if it is to be a street car. However the microtech in sequential mode is probly a little bit better than the motec in batch fire and its allready setup and tuned so I would be leaning on going down that path.
so how much will i need on the side to spend???
get 3 coils? theyre 50each.... then the motec ignition expander? would this be all i need to spend? (the car will probably be making around 400-450rwhp and thats through an auto transmission)
coz im pretty tight atm... lol and this pisses me off all these things about "batch firing" and "sequential"...
*sigh* wish i wouldve just bought an m600 from the start
Edited by gnki'vlct
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to it's full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so damn hot in there, that made it all the more easy to remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. I was standing there looking at the car and said 'f**k it'. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
