stephen, if you carry 2 wheels for me, I'll give you a pair of brand new sony 6 inch speakers ( think 2 way or 3 way) i have here. I bought them for my GTST but never got to fit them before I sold the car. :P
everyones a winner!
  • Replies 665
everyones a winner!
if he doesn't take you up on that deal i'll make them fit!
everyones a winner!
oh yeah... sounds good ill take u up on that. ill send u a PM to organise how we'll do this
lol, don't worry, beer baron has something for everyone! It means I can take the jack and stands now. Of course anyone is free to use them as needed.
I might have a passenger for you if ok, As we will be taking a little car and have 4 in with us and for 7 hours could get a bit cramped
Oh what :P not crashing with us....
That would be cool.
I'll be travel pretty light so I expect I'll have room for gear I'm light in the tool department (I'm an optimist).
Sounds like a couple of us are coming from the north shore - I'm in Cammeray right off the freeway and not far off of Military Road - happy to use that as a meeting point.
I wont be in the car anymore Jess :( I thought of that already and I am going to keep Chubbs some company..
That would be cool.
Yeah could do as we are from North shore also
Aww what getting ditched already :P That's cool
Aww what getting ditched already :rofl: That's cool
Haha I dont mean it like that hun.. It might be a little squishy.. I dunno if i could put up with Shawn all the way there.. hahaha..
I will cb whore to you in the car :P so we will always be close.. :(
Ok, so ive sent Tim the bank details, and Jess you said you sent them to SAM916?
Is that right?
Yes, every driver will need an L2S, they're easy to get and last a year (they're also the same ones we use for our trackdays etc so dont throw it away) :P
Meet point will be in Beverly Hills as there is a huge carpark right next to the motorway entrance so its easy to meet, and there is a shop there to buy drinks/junk food/porn for the drive down. Ill post the exact details and a pic of the point closer to the date
Ill get onto netbank right now and confirm payments (sorry guys ive been pretty busy lately - whats new....)
Oh and one other thing thats pretty important that everyone should know...............ALWAYS give Smoky a huge :) when he's driving on the skidpan ;)
Ok.............so only one person used the ID box.........that was evilweevil - can anyone still waiting for confirmation please PM me what you wrote on the trasfer so i know who's money is who's?
Cheers
forgot this link...
yeah, that was not a good effort. and it's quite strange as lots of the guys who hang out on oxford street have told me that ordinarily steve loves to swallow the worm. i'm not quite sure what they meant buy that. weird.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
