Righto so ive got the impression that my pump isnt working. Although as far as i know the engine hasnt seized up and its not making any nocking noises yet. So im wondering has anyone changed the oil pump on there car or payed someone to do it and how much did it cost? I would probably rather myself do it because there isnt really many machenics i would trust where i live, but if its a straight forward job id pay someone to do it over myself doing it. My mate said i would have to pull the engine out... but i dunno, if i had to go to that much trouble i would just buy another engine or rebuild it anyway. Ive had a look at some diagrams of the RB26 yeah yeah it doesnt look easy. hope someone can help
Cheers
https://www.sau.com.au/forums/topic/159217-changing-r32-gtr-oil-pump/
simplified version :
Removal:
Remove Harmonic balancer and timing gear on the crank. including half moon keys.
drop the sump down about 20mm at the front
undo all bolts on the oil pump and slide forward.
Install:
new oil pump gasket,
install pump back onto crank collar,
bolt up in order specified in the workshop manual
reseal sump and bolt onto block
reinstall timing gear and belt and balancer.
prime oil pump by pouring oil into the outlet pipe on the oil filter assemply
crank engine without spark or fuel to confirm oil pressure
  • 3 months later...
I had a quote for and engine out engine in for 2 grand.
Thats just taking the engine out so i can work on it and then one i am done putting it back in.
I have been told you need the engine out for a GTR rb26 (in the r32 anyway) because of all the gear under the sump not allowing you to drop it.
Just what i have heard no practical expirence. (yet)
Unfortunately with early R32 RB26's it's not as simple as just changing out the oil pump.
Early RB26's ran a much shorter drive collar on the crank snouts & the only way to rectify this is "engine out, crank out". From there you can either choose to have an extended collar fitted to your existing crank, replace it with a later model item that comes from the factory with the longer crank snout or go "all out" with a stroker bottom-end from HKS, Jun etc.
With the cost & effort involved to go this far it's a good idea to look at the viability of re-building the rest of the engine. Forged pistons are good insurance for when you get the bug & want to run more boost & whatever you do, NEVER RE-USE OLD ROD BOLTS!! Have the rods prepped, re-sized, new bolts & you should be good-to-go.
Another option worth considering is going to a dry-sump setup. A lot of people consider a dry-sump to be over-kill for anything short of a dedicated race car but with a well sorted GTR they are almost mandatory in my opinion. Not only will this take care of "oil surge" by making sure the engine has a supply of oil 100% of the time, by plumbing a scavenge stage to the back of the head it stops all the oil collecting in the head & away from the pick-up as tends to happen with the factory wet-sump.
I am about to start offering dry-sump systems initially for all RB-series engines on a "change-over" basis, meaning, where possible, we can ship out a complete kit incl sump & once you fit everything, you send your old sump back so as to minimise the amount of time your car is off the road. Also by the time you factor in the cost of a new or modified crank & new N1 or Jun oil pump (which you won't need with a dry-sump) & an extended & baffled sump etc a complete dry-sump system becomes a lot more financially viable than most people think.
For more info, prices etc on all of the above, send me a PM or call anytime
:action-smiley-069:
John
0413 615955
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
