hey guys sorry if this is already some where on the forums , at first i stated i wanted a r33 although a certain r32 has caught my eye, i was just after ur own opinions , pros / cons on both models , so i can get a bit more of an understanding of what im really wanting out of a skyline
thanks alot jarryd.
https://www.sau.com.au/forums/topic/159371-32-or-33/
  • Replies 63
Posted Images
Well most people who have R33s would say get an R33 and most with R32s would say get an R32. It really comes down to personal preferance. I would say get an R33 (not just because I own a R33), this is because they have more room then the R32s and also they a are newer vehicle with a larger motor.
At the end of the day it is your decision and you should shop around and make sure you buy what you want.
Chris
https://www.sau.com.au/forums/topic/159371-32-or-33/#findComment-2958105
I've got a 34 so I won't be biased here. If your budget only allows for a 32 or 33 I would go for a 33. 32s are getting on with age and its harder to find a good example. Reliability is more my concern and hence the newer option. Tht doesn't mean the 33s won't give you any problems as well. Choose carefully and get it well inspected b4 u commit.
https://www.sau.com.au/forums/topic/159371-32-or-33/#findComment-2958126
id definitely go with R32, but i am biased :ninja:
i just find they are lighter, and easier to work with.
Depends what you want to do with it also... whether it be for motor sport, cruising, or just daily fun...
definitely a personal preference, but the 32's (imo) just look a lot cleaner and tidier and they have a such a sexy bum lol (but id definitely agree with the R33 engine part :laugh: )
Edited by skygrrl86
https://www.sau.com.au/forums/topic/159371-32-or-33/#findComment-2958194
ive owned 2 33's one of them being a gtr.. however if i had a low budget id buy a clean 32 if you can find one.. if spending aroudn 17-22 id invest it for a 33 which you can buy decently now days .. only reason i sold the 33 was being old 97 model as opposed to the 34.. plus the looks personally 32's look tougher .. 33's are bigger and more floater ... 34s are much of a combination of both .. go 33 if u want room .. 32 if u want a car that you wont keep for long.. if i where in your shoes.. id buy a mid prices 32 .. simple mods and keep it for a few yrs.. only coz i havent owned a 32 .. (32 GTR's are nearly same price as some late S2 97+ model 33's) so thats another thing to consider.
Whichever you buy get it for your own reasons.. importantly take your time !..
https://www.sau.com.au/forums/topic/159371-32-or-33/#findComment-2958195
33 FTW!!! much better looking but that just my opinion! Mine gets alot more looks then some mates of mine who have 32's
https://www.sau.com.au/forums/topic/159371-32-or-33/#findComment-2958231
33 for me. I looked around a bit and for me the 33 did it. there are some shit hot examples of 32s getting around but by and large i found too much of the boy racer deal attatched to them.
The 33 has a tad more conservative appearance but can be modded to freakin hawt if you want.
At the end of the day its your call. They are all good cars if you take care of them.
https://www.sau.com.au/forums/topic/159371-32-or-33/#findComment-2958416
ahah u have that boy racer image noel... chrome wheels yo. :(
https://www.sau.com.au/forums/topic/159371-32-or-33/#findComment-2958455
both GTST models look crappy.. sorry guys but skinny guards do do it to ya. the GTR versions are better. and the BNR32 is the best..
the R34 GTT is quite nice even though its not fat.. we own both so im very biased..
buy my GTR and offer more than wat lee is offering.. :(
ahaha jokes :rofl:
https://www.sau.com.au/forums/topic/159371-32-or-33/#findComment-2958572
ahaha jokes :rofl:
yeah they are just not wide enough are they
https://www.sau.com.au/forums/topic/159371-32-or-33/#findComment-2958698
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
