Hey.
I'm just wondering, are these the stock shock absorbers? as one of the back ones is crook. so i'm thinking of replacing all 4. but i need to know if the ones on it are the stock Nissan ones.
and
The springs? do you know who makes them? i'm guessing there not genuine Nissan because the car rides hard as a rock.
Thanks in advance.
https://www.sau.com.au/forums/topic/159535-suspention-setup/
Based on the apperance of the shock and the dust boot, they are standard shocks.
The springs are LOVELLS coils. My guess is that the car is very low and sitting on the bumpstops as the rate on those wont make the car ride hard (very soft rating). Generally LOVELLS springs dont go very low, so my next thought would be maybe they have been cut to get the lowest possible ride height. Are they captive at full droop??
Cheers
Brad
Captive at full droop means when the shocks are at full droop (eg, car is jacked up and wheels are sagging all the way down), the springs are still held firmly by their preload and can not move.
Your fronts are captive at full droop in the front. Dont know about rear as we cant see them.
They are a progressive rate spring so i am a little surprised about your comments on the ride quality. The rear may not be though so i can't comment there.
Aftermarket springs on stock shocks is never the best idea from a performance point of view. I'd suggest a decent set of stock replacement aftermarket shocks.
I'm surprised no one has told you to to buy everything listed in the sydneykid group buy yet. Check with sydneykid to see if the bilsteins offered will be compatible with your springs, you get the added advantage of circlip height adjustment with these shocks too.
If all your chasing is a decent shock absorber with out spending the earth, or going as far as the coilovers, KYB shocks are pretty good for a standard replacement. They are not performance orientated or adjustable or anything like that, just a decent quality standard replacment.
Hope that helps.
Brad
This thread runs through why having lowered springs and standard shocks is not a good idea.
http://www.skylinesaustralia.com/forums/in...c=103158&hl
As for heights not being too low, what are they, centre of wheel to guard on all 4 corners?
If they are less than 350 mm front and 340 mm rear, then it is too low for good handling and decent ride comfort.
Since the car is "just imported" then chances are they won't be Lovells (Australian) springs. My guess is some brand of Japanese springs, not a well known one, since none of them are that colour blue.
This thread tells you how to measure the spring rates;
http://www.skylinesaustralia.com/forums/in...showtopic=79157
That way I can tell whether they are stupid Japanese rates or not. Since they are progressively wound, you will have to tell me the gaps between the coils. For example, in a 10 coil spring, 5 coils are 10 mm apart and
5 coils are 20 mm apart.
The Whiteline springs in the Group Buy are $144 a pair, so not a big expense if the ones that you currently have are not suitable.
Reply PM sent regarding your query on Group Buy prices etc
:) cheers :(
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
