I have a manual 93 gts25t and so far ive done the basic stuff like good exhaust, air filter, EBC high boost set to .8bar, BOV (yes i noticed a difference boost kicks in faster on gearchanges) Good tein adjustable suspension. It has 17" 255's all round. If i go too hard on it and get wheelspin its just too much for the clutch and it slips and i get that burning clutch smell heh. So, i need a better clutch, keeping in mind that i wont be going for bigger turbo and all that stuff, i'll just be doing a few more minor mods so i wont be expecting any more than about 200rwkw by the time i'm finished.
Firstly what type of clutch would you guys recommend as something that can handle lotsa abuse with around that power output. If you could include rough prices or links that would be really helpful.
And while i'm at it i might as well put in a light flywheel so any prices etc on that would be great too.
https://www.sau.com.au/forums/topic/15954-r33-clutch-and-flywheel-upgrade/
warrior_350,
I would go for something like a replacement full face (steel backed) organic heavy duty clutch (with increased clamping rate)
Both Unique Auto Sports and Just Jap sell them for around $550 I think..
This is what I will be looking at getting soon and I have the same requirements as you...
I know your in QLD but have a look (on their web sites) and order it through the site (and have your local mech. install it etc..)
Regards
Yeap! I'd go a good quailty full face clutch with a good lightened flywheel.
If you car is going to be a daily driver, then you'll wear a button clutch quickly and it will also piss you off very very quickly.
Guest INASNT
Originally posted by GTS-t VSPEC
I have a twin-plate OS Giken, and while it may be overkill for what you need, they are nice to drive and come with a lightened flywheel. See if there are any 2nd hand ones going:D
isent that an on/off clutch and a bitch to drive in traffic?
Extreme single plate ceramic button clutch with sprung centre and heavier pres plate, cost me $880 fitted. Sprung centre so wont piss you off, easy to drive for a performance clutch. Very good feel and take up, i have 200rwkw and its fine, whatsisname has the same clutch handling over 250rwkw. recommended.
Nah dude... i have one with the solid center. I think the ones with the smaller pucks are harder to drive as there is more pressure on a smaller surface area. The OS Giken plates have 4 large pucks, and i find it quite easy to drive. Peak Hour is a pain... but isn't it always?
i have a hks twin in my car. grips like mad, no play at all. moving off on a hill is a pain.
from what i've heard, nismo, os giken and ats make clutches for road use. the one i have in mine is a race clutch. i was told this after i put it in...could have gotten either one of those other 3 for the same price...
Where you can get them? thanks
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
