looking for an exhust system as my first mod. i own a 95 r33 - a "s1.5". what are people's opinions on getting a trust PE II catback vs a X-force turboback. they are $899 and $950 respectively from justjap. if people could answer the following questions it'd be really helpful:
1. why is the trust system only 50 bux less than the X-force?
2. both are 3 inch so what is the performance difference between them, taking into account that 1 is a turboback
3. how durable/reliable are the 2
4. are they direct bolt on or will i (read the mechanic) hafta stuff around?
5. im looking for sound that is noticably louder than stock but no where near the "look at me, im fully sick" drones and volume levels some cars have. ie. i want it well below legal limits. which is the best fit for this?
6. i had a question six but my brain has just died so yeh...
thanks in advance.
p.s if you guys have sugestions 4 othe systems that fit my needs feel free to lemme know. pricing and where to get them would be nice
https://www.sau.com.au/forums/topic/159582-exhausts-help-me-choose/
thanks in advance.
1) Trust system is only Catback.. You pay for the name
2) Trust system will be quieter
3) No idea.. althought the trust system is stainless.. so should last a while
4) Yes.. but that doesnt mean there wont be a few swear words and bloody knuckles
5) Get the Trust system (plus dump and high flow cat).. Xforce will be loud.. and pretty much every aftermarket system will be over the legal limit
6) Yer that happens sometimes.. its called a "Brain-Fart"
Edited by MotoMan
I've just been thinking the same thing with my exhaust.
I want something that sounds good normally, not droney and overly loud cruising, but great when I open it up.
If you do go with the Trust PE II get it from nengun, much cheaper!
http://www.nengun.com/trust-greddy/power-extreme-ii
Currently have a tanabe cat back on my R34. Its quiet as when idling and at low revs, and when you put your foot down ya get that sweet sound of the RB :P Not sure of costings cos it came from japan like that... hope this helps...
I have a HKS super dragger... its a deep sound but not where near as loud as a the common cannon exhaust... but its an 8" barrel and 5" tip LOL massive bastard
if you want quiet and low profile go for the magnaflow... someone on here is currently selling a cat back... nothing special in looks but its quiet and does the job :P
thanks in advance.
The which exhaust question gets asked almost on a weekly basis. A search b4 post answers most of ur queries. Get a turboback woteva u can afford to. Here's a post from last week http://www.skylinesaustralia.com/forums/in...howtopic=159310
So if $950 is ur budget get the X-Force turboback or buy a split dump, hi-flow cat & used catback, hav a look in For Sale section. Oval mufflers will give u a lesser flow but less noise/drone, round mufflers will give a better flow at the cost of more noise.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
