OK GUYS AND GIRLS WE ARE NOW 3 DAYS OUT ALL PERSON WHO WISH TO COME PLEASE PM ME OR CHEEZE THAT YOU ARE COMEING IF YOU ARE UNDECIDED OR DECIDE TO COME AT THE LAST MINTE WITH OUT TELLING ME OR CHEEZE YOU WILL BE LEFT BEHIND IF YOU GET TO THE MEET POINT LATE. HOPE TO SEE YOU THERE.
GOR Cruize - little river to apollo bay.
DATE: April 7 07
TIME: 9.30am meet for 10.30am depart.
WERE: servo at little river (out front of averlon airport) on the princes freeway.
CB RADIO CH: 14 (code 00)
FUEL: Full tank + jery can (if your car drinks)
CRUIZ INFO:
so ive thought i would see who would like to do a second cruiz for those who couldn't make it or ant a member. so here it is.
If you have any problems on the day you can contact me on 0411 895 116 or PM me before hand.
chears brentt
pic from this years cruiz
http://www.skylinesaustralia.com/forums/in...howtopic=158973
Definitly Coming:
redlineingr31skyline
cheez + 2cars
kylie
slayer_1971
mcdee
spin-psycle
GTS4-32
sillylankan
Borgs
aaron_25t
ImTheJuggernautBitch
Pax-Ottomanica
Turko
TTerminator
Blade
JET RB
SNISMO
jake33
dilmah
B-rad33
R324DR+1
shadow GTR
32 Sedan
32 GTR
32 GTR
VX SS
Monaro
XR6
ICER33 + 4 (MEETING US ON THE RUN)
700hp-GTR33
wrxgav
malz34
This is an unofficial SAU VIC event. There will be no facility for non-members to signup. There will no merchandise provided or any other official club materials.
There is NO event insurance or coverage for this event and SAU VIC will not be held liable for any activities or actions on this event.
It is in the public event section and what you do in your own time is upto you, but it cannot be sanctioned as an official SAU VIC event.
We the committee have edited this thread accordingly to reflect that.
Regards,
SAU VIC Committee
https://www.sau.com.au/forums/topic/159782-unofficial-great-ocean-road-cruise/
  • Replies 150
hey man i definitly in.
just a thought tho, might be worth seeing if we can organise 1 b4 the end of march say the 24th/31st, this way we got a better chance of good weather. dont think you'll get a big turnout if its raining?
see how many pplz can make each of these dates.
guys post up your preferred date for the cruise:
a) 24 mar
b) 31 mar
c) 28 apr
if we can org 1 earlier i def got pplz who are in for that.
i was concidering the 7th but being close to easter i thought people might not come.
the 24 and 31st will be out for me as im working at the airshow on the 24 and the 31st thier is a race meeting at PI.
so dates will either be the 7th, 28th april or
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
