  • Replies 109
  • 9 months later...
NXTIME....I suggest you get in contact with me, sooner rather than latter.
ITEM: As new 05U RB26 block fitted with HKS 2.8L Step 2 stroker kit
CONDITION: excellent
PRICE: Cost $16K+ asking $9,000 or near offer
PICS: on request
OK charlie (NXTIME).....you've had 2 years and you keep making promises, but keep failing to make payments back to me....the HKS kit was returned to you....I WANT MY MONEY BACK NOW
If you have a grievance - i suggest you fully detail it and PM me with the information GTR STI.
Mind you, if its not details and contains no evidence... then you will have to keep your opinion to yourself.
You can't run around without solid evidence (email, PM and so on).
And for you sellers - you know the deal, i hope this isn't a deal gone bad from your end
Yes...have it all....charlie was to make a payment to-day....never happened....but he has been going to make payments for a while now, but never does.....Blitz is totally aware of this situation and at one time had a talk to him early in the peace......but now I am sick and tide of NXTIME promises. This was an $11000 deal gone wrong.
I hope he realises that I've now had enough....and he needs to rectify the refund as a proirity.
  • 2 months later...
My plans have changed and I am no longer going to be building a drag car so it's time for these parts to go to fund further upgrades for my car:
ITEM: 800hp+ RB26 HKS Twin GT2835 turbo kit; exhaust manifold, wastegates and rear turbo housings have been ceramic coated; comp housings have been polished. Also comes with dump pipes and polished stainless steel intake pipes and K&N filters.
This kit made 546rwhp@16psi on initial tune. Will make over 700rwhp very easily.
CONDITION: Very good used (~5,000km)
PRICE: now $4,500!
PICS: below
Item: GTR Trust/GReddy twin entry drag cooler 600 x 300 x 150mm with 2 x 60mm inlets and 100mm outlet
Condition: Excellent - as new.
Price: $1,800ono
To Fit: GT-R's or whatever you like
Contact: PM
Comments: No longer needed as I have changed my mind again and am upgrading.
ITEM: Apexi V-MAX SPL forged billet 2.6L crank
CONDITION: Excellent used
PRICE: $3,300
OTHER: Can be revved to 10K+ with the right head components; rated to 1000+HP.
PICS: on request
ITEM: RB26 Apexi V-Max 270 deg 11.4mm camshafts.
CONDITION: Excellent - unused
PRICE: $900ono
ITEM: RB26 Apexi V-Max 9,000 rpm valve springs and retainers
CONDITION: Excellent - used for 1,000km.
PRICE: $700ono
Or Cams, springs, retainers for $1500ono
No timewasters or lowballers.
Do you still have the 2.8 stroker kit with block in need of bottom end rebuild with good block
  • 3 months later...
Hey mate is the hks stoker kit engine still available? can you email me some pics to [email protected]. Anythink else done to the engine at all? Has the engine been run in? reciepts. And also pics on apexi cams, valve spring retainers and retainers. Thanks
  • 4 weeks later...
hey mate
I am chasing a set of Throttle bodies and intake manifold for the RB26. Do you have any for sale?
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
