  • Replies 133
ok, can somebody PM me with the car yard.
I know a guy who is very high up in Main Roads in the traffic inspection area.
I'll see if i can get hold of him for u Amy. (he is VERY busey man)
I used his services about 4 years ago and got a workshop shut down for dodgy roadworthies... and they still to this day have not paid for the repairs! (thats another story!)
AFTER you get ur sweeet ride back, do all import drivers a favour and ring ACA and today tonite.. even a very large news paper! let everbody know about these jerks.
I think I saw ur car in the area that u found it.. i was checking out the rear apron on it! Nice car!
I travel from Brizzy to Hearvey Bay weekly for workl. I see lots of nice imports.. I remember things that nice!
Well, at least you found it! GPS tracking for your car hey?
Aaron
got it back. WE think the km's have been wound back. the front bar has cpme off on one side (going down driveways). Other then that everything seems ok. i got a GTR wing out of it so far. but we will wait until the owner comes back from holdidays
any new developments?
one thing I just remembered reffering to the car yard in question,
Back when it was melb cup day my mates car was back for like the 10th time to be fixed (same problem every time) he had aranged with the owner of the yard to have his car dropped off to him at work (because he refused to drive the totaly unroadworty POS Loan car any more)
Anyway come 5pm my friend call to make sure the car will be dropped off and the receptionist informs him that "the boys have had a few too many to drive, you will have to come pick it up yourself" at this he became very pissed as this meant asking his boss to leave early yet again
None of this mattered anymore as minutes later he got a call back from the receptionist saying that the car was on its was, his comment to her was so a couple of drunk guys a driving my car back? there was silence on the other end...
Sure enough his car came screaming into his work place driven by the guys that had a few too many to drive... the car smelt of clutch/brakes as though it had just been thrashed... what more can you say...? and it was still playing up!
Anyways the end of the story to date is his car is now fixed by another mechanic and has been trying to get reimbursement from the said car yard, will see what happens as he dropped off a 4 page letter of demand yesterday and plans on taking them to court as it cost around $600 to get it running right.
should post the name of the business. it sounds fair that everyone knows the name of the company as someone this dodgy should not be in business. if they go out of business so be it!!
Think of how many people you could stop this from happening to. something to think about......
Please keep the business name to pm's... (If you must know)
I dont want slander on the open forum... Thanks bye...
PS> I spotted Amy Lee at the gold coast last week :P
I gave the young female driver some sun screen so she didnt get burnt on that hot car...
(pun intended) :O
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
    • So I found this: https://www.efihardware.com/temperature-sensor-voltage-calculator I didn't know what the pullup resistor is. So I thought if I used my table of known values I could estimate it by putting a value into the pullup resistor, and this should line up with the voltages I had measured. Eventually I got this table out of it by using 210ohms as the pullup resistor. 180C 0.232V - Predicted 175C 0.254V - Predicted 170C 0.278V - Predicted 165C 0.305V - Predicted 160C 0.336V - Predicted 155C 0.369V - Predicted 150C 0.407V - Predicted 145C 0.448V - Predicted 140C 0.494V - Predicted 135C 0.545V - Predicted 130C 0.603V - Predicted 125C 0.668V - Predicted 120C 0.740V - Predicted 115C 0.817V - Predicted 110C 0.914V - Predicted 105C 1.023V - Predicted 100C 1.15V 90C 1.42V - Predicted 85C 1.59V 80C 1.74V 75C 1.94V 70C 2.10V 65C 2.33V 60C 2.56V 58C 2.68V 57C 2.70V 56C 2.74V 55C 2.78V 54C 2.80V 50C 2.98V 49C 3.06V 47C 3.18V 45C 3.23V 43C 3.36V 40C 3.51V 37C 3.67V 35C 3.75V 30C 4.00V As before, the formula in HPTuners is here: https://www.hptuners.com/documentation/files/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm?Highlight=defining a transform Specifically: In my case I used 50C and 150C, given the sensor is supposedly for that. Input 1 = 2.98V Output 1 = 50C Input 2 = 0.407V Output 2 = 150C (0.407-2.98) / (150-50) -2.573/100 = -0.02573 2.98/-0.02573 + 47.045 = 50 So the corresponding formula should be: (Input / -0.02573) + 47.045 = Output.   If someone can confirm my math it'd be great. Supposedly you can pick any two pairs of the data to make this formula.
