Hi all i thought that i would start my own thread on shimming of the differential for skylines.in particular the R33gtst.though any input is appreciated.
Could you give me some insight as to how it's performance was/is and what size shims you used.I am doing the sau drift day,am really in need of an lsd,but shimmig is the only way for me to go due to cost atm,and i only have a vauge idea on what shim size to go for.Basically all shim sizes ive been told about and their results are from nissansilvia.com.and they are all different cars IE:silvia's,180's etc..
I would rather a real world skyline point of veiw...
Here is the link to my diy thread for diy:r33 gtst diff shimming
Well ive ordered a 1.3mm and 1.4mm shims havent decided which one to throw in with the stock 0.8mm shim yet.but the good news is that its on its way.
The bad news is that its due arrival date is dangerously close to the sau drift weekend.ie: that week. :?
0.80mm = 3842440f60 price = $10.12
0.85mm = 3842440f62 price = $14.67
0.90mm = 3842440f63 price = $9.97
1.01mm = 3842440f67 price = $9.79
1.05mm = 3842440f68 price = $14.40
1.10mm = 3842440f70 price = $6.37
1.20mm = 3842440f73 price = $6.37
1.30mm = 3842440f76 price = $10.89
1.40mm = 3842440f80 price = $6.37
1.49mm = 3842440f83 price = $6.37
what size shim did you throw in?
Ive read on d1nz forums that the diff can be shimmed on both sides.If what you are saying is true then i believe you may require one either side.
There are others on there who have said their lsd had been going strong for more than a year with only having the shim on one side.
Ok well i followed that D1NZ site i bought ONE .8mm diff shim, opened my diff up and slapped it in as per the D1NZ site...put it all back together and it was harder to put the center back into the housing, maybe cos the shim made the whole centre .8mm thicker, if you go any bigger you might have to take it to a diff lapper and get them to make sure the backlash is set right so you dont snap teeth of the pinion gear. But seriously the diff shim in my 32 only lasted like 2 weeks and now its back to the way it always was...i think the shim just wears out really fast cos the center isnt suppose to have that much tension. I read that there is another shim on the other side but i never seen that part, and everyone that has shimmed their diff only ever does the one side.
I can confirm that it will only last for a matter of weeks/months.
I shimmed mine 2 months ago and it starting to open wheel on tight corners under hard throttle.
it is coming out and a 2 way LSD is going in soon :(
Thanks for the reply.
I now am having my reservations about going through all that effort just to have it return to shit..Plus
i was going to throw in a bigger shim.1.3mm on top of the 0.8mm.
Really,i will see what i can do.It will be so close to drift day that i will be getting shim annyway that if anything goes wrong and i need a pro to fix it i will be up shit creek.
What kind of timeframe am i looking at in and out by myself?and is there anything that i should know about taking the hicas out and reinstalling it.any unforeseable problems that i might encounter?
Regards
Craig.
I looked into this a while ago for my car and the place I spoke to said they could do it but it would go bad again soon. So there's confirmation I guess.
I'm selling my Nismo 1 way in a few days... fits in r33's not sure about R32.
Has anyone had one stay tight, after hard driving AND daily driving? I've read the D1NZ forum, and one guy reckons He CAN'T get his to loosen up! I'm wondering if the guys who's Diffs stay tight after the mod are using Redline or something, to stop wear?
And can anyone confirm, or deny that there's a 0.8mm shim BOTH sides from factory?
Thanks.
that i do not know.yet!but if i can i will get a pic of the other side of the diff if it is not a task to do it.Though i and waldo have read that there is definently one on the other side.The diff oil i am using to refill it with is penrite.
spent up on the gearbox oil though.Penrite 10tenths @ $60 per 2.5l and i bought 2 of them.with a 20% discount card.yeah baby!so far through the week i have noticed remarkably smoother gear changes.Needs to be warmed up before getting into it though.
Atm the diff is on the garage floor.i will pull it apart tomorrow when daylight graces.
Happy easter.
Happy easter.
Sweeet - thanks dude - 'coz I'm thinking, if there's Two 0.8mm shims from factory, I'll replace them with Two 1.4mm shims, - that'll keep everything nice and centered, and clamp it a total of 1.2mm tighter - about middle of the road, compared to what everyone else has done on the D1NZ forum.
Have good Eastering ! :wave:
Hey mate.I can confirm that they do have 2 shims one either side.i have pics of them.
On mine it had allready been swapped on one side for a 1.1 shim and still had the stock one in there on the opposite side.
Trust me it will take you 30sec to get at the outer side once you have the inner side in front of you.
What i have done is take the stock 0.8mm shim which was more like a 0.711 shim (worn).and added that to the other side allong with the new 1.4 shim.And threw the 1.1 shim (more like 1.0) on the other side.
Am going to fit the diff tomorrow.it should work well.2.1-2 on one side and 1.0-1 =3.1-3.
I've done one of my VLSD's.
General low speed driving I didn't like how it unsettled the rear as I could feel the spider gears binding and then letting go on low speed corners so wobble wobble around round abouts. :thumbsup:
Straight line acceleration it made no improvement, single spinner.
Corner exit it was excellent, always twin wheeled and sent the car all crossed up nicely.
So this bodgy mod isn't for any one who is chasing a little more straight line grip from their tired VLSD.
If you want improved corner exit grip or drift then the shim does work well.
I used an extra 0.8mm shim.
With a little more preload I think mine would have acted much like a locker, so it 'may' have improved straight line acceleration but most likely not.
Also.. ~1000-2000km's the clunking etc will dissapear as the spider gears wear, I noticed the locking affect also diminishes slightly lol :)
Have good Eastering ! ;)
There's absolutely no benefit of doing this, it being centered doesn't matter.
I could only get the shims from nissan.
Well i drove it this afternoon.
And can safely say that it is virtually a locked diff.Seen as though i have never driven a car with a locked diff,only ever been a passenger in one,i can safely say that this is going to work well for drifting.
Reversing out the driveway was new to me.chip,chip,chip...
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
