satanic Posted April 4, 2007 Author Share Posted April 4, 2007 First payment has been made by Omurru Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3028562 Share on other sites More sharing options...
GTR32GUS Posted April 4, 2007 Share Posted April 4, 2007 First attempt at a table;-------------------- -------------------- RB26 -------------------- -------------------- RB25/20 -------------------- -------------------- -------------------- RB25 -------------------- -------------------- No VVT -------------------- -------------------- No VVT -------------------- -------------------- -------------------- VVT -------------------- -------------------- Front Feed, Rear Feed -------------------- Front Feed, Rear Feed -------------------- VVT Supply, Front Feed, Rear Feed Standard Oil Pump Road ----------------------------------- 1.5 mm, Block off, ------------------------------ 1.5 mm, Block off, ------------------------------ Leave, Block off, 1.5 mm, Drag ----------------------------------- 1.25 mm, Block off, ------------------------------ 1.5 mm, Block off, ------------------------------ Leave, Block off, 1.5 mm, Circuit/Drift ------------------------------ 1.25 mm, Block off, ------------------------------ 1.25 mm, Block off, ------------------------------ Leave, Block off, 1.25 mm, RB26 N1 Oil Pump Road ----------------------------------- 1.5 mm, Block off, ------------------------------ 1.5 mm, Block off, ------------------------------ Leave, Block off, 1.5 mm, Drag ----------------------------------- 1.25 mm, Block off, ------------------------------ 1.5 mm, Block off, ------------------------------ Leave, Block off, 1.5 mm, Circuit/Drift ------------------------------ 1 mm, Block off, ------------------------------ 1 mm, Block off, ------------------------------ Leave, Block off, 1 mm, Aftermarket Oil Pump (Jun HKS Apexi Trust etc) Road ----------------------------------- 1.25 mm, Block off, ------------------------------ 1.5 mm, Block off, ------------------------------ Leave, Block off, 1.5 mm, Drag ----------------------------------- 1 mm, Block off, ------------------------------ 1.25 mm, Block off, ------------------------------ Leave, Block off, 1.25 mm, Circuit/Drift ------------------------------ 1 mm, Block off, ------------------------------ 1 mm, Block off, ------------------------------ Leave, Block off, 1 mm, Note that all of the above assumes; 1. Standard Nissan clearances 2. Oil cooler (where necessary) 3. Improved oil control in the sump (where necessary) including wings, baffles, one way doors etc 4. External oil return from cylinder head to sump on all circuit/drift cars and drag cars with non standard oil pumps 5. Hydraulic followers in RB20/25's. if changed to solid followers then use RB26 restrictor as above 6. Castrol Edge 10W60 (or equivalent)\ 7. Improved oil flow in the cylinder head return galleries through the block. 8. Refer previous posts in this thread cheers PS; This guide is for what ever cylinder head you use, the block is irrelevant. Whether you use an RB20/23/24/25/26/27/28/30 bottom end is doesn't matter when it comes to restrictor sizes. It's all about what oil pump you use, what cylinder head and what you use the car for. Here a table from Sydneykid for picking what restrictors u need , Pm sent as well Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3030463 Share on other sites More sharing options...
satanic Posted April 4, 2007 Author Share Posted April 4, 2007 Thanks bud... I purely went off what Matt said; but with this table I think everyone will be able to see for themselves what is required. Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3030513 Share on other sites More sharing options...
Adriano Posted April 8, 2007 Share Posted April 8, 2007 (edited) Im in for a set, just let me know when your ready to go ahead Edited April 8, 2007 by Adriano Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3036815 Share on other sites More sharing options...
satanic Posted April 9, 2007 Author Share Posted April 9, 2007 PM sent and name added to list... Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3038223 Share on other sites More sharing options...
GTR32GUS Posted April 10, 2007 Share Posted April 10, 2007 Pm sent Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3039067 Share on other sites More sharing options...
satanic Posted April 10, 2007 Author Share Posted April 10, 2007 PM Received; Status Updated. Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3039081 Share on other sites More sharing options...
satanic Posted April 12, 2007 Author Share Posted April 12, 2007 Adriano; status updated! Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3046345 Share on other sites More sharing options...
satanic Posted April 15, 2007 Author Share Posted April 15, 2007 sky30; status updated... I will call Matt sometime today and ask if he can do the cheaper price for the 4 sets already paid for... this will move things along faster. Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3051711 Share on other sites More sharing options...
satanic Posted April 16, 2007 Author Share Posted April 16, 2007 I called for Matt yesterday afternoon but he was off sick; have left a message for a call-back today and it should be all good! Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3054037 Share on other sites More sharing options...
satanic Posted April 18, 2007 Author Share Posted April 18, 2007 Update; all the crank collars have been paid for and will be sent out (to me) by the end of the week; I'll ship them all off as soon as they arrive. FYI Matt from NZ is an awesome guy to deal with; honest and to the point - so if you need anything from NZ; go through him Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3057273 Share on other sites More sharing options...
Adriano Posted May 9, 2007 Share Posted May 9, 2007 Any updates with these? Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3107634 Share on other sites More sharing options...
satanic Posted May 9, 2007 Author Share Posted May 9, 2007 Hey all, As far as I was told, Matt had sent them off yesterday. They had to get the 1mm restrictors machined up as they had run out at their shop. Thanks Stan Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3107794 Share on other sites More sharing options...
munro'sgts-t Posted May 28, 2007 Share Posted May 28, 2007 hey im very interested cos i will be needing thse for my rb25/30 combo, just wondering if this buy is still going and if you could pm me the payment details. im after one crank collar and 2 restricotrs at 1.5mm possibly 1.2mm will get back to you on that one Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3146787 Share on other sites More sharing options...
satanic Posted May 30, 2007 Author Share Posted May 30, 2007 Just received a call from DHL; the collars have been sitting in a holding facility for the last week! Apparently (truth level of this unknown) the address was listed as 39 and not 59!!! How bloody nice of them to call me after a week~ Anyways, just letting you all know that they will arrive tomorrow and I will be shipping them out to you on Friday Happy Times! Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3151336 Share on other sites More sharing options...
Omurru Posted May 30, 2007 Share Posted May 30, 2007 yay not that I have a block ready yet I blame the fact teflon hose fittings are so god damn expensive Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3151945 Share on other sites More sharing options...
Adriano Posted June 6, 2007 Share Posted June 6, 2007 received mine today, thanks stan. Looks good, but no grub screw(or hole)? I understand its not essential, just for safety, btw do you know how much interference fit these are supposed to have? Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3164077 Share on other sites More sharing options...
satanic Posted June 6, 2007 Author Share Posted June 6, 2007 Hey Adrian; The grub screw should be in the packet; I personally checked all of them before sending out it's a tiny little black thing - perhaps check that it didn't fall out into the tough bag? Also; there's no hole in the collar because the grub screw is really an "optional" item that not all places choose to use. As such; no pre-machined hole is drilled for it. This is what I've been told by Matt any ways... Thanks S Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3165098 Share on other sites More sharing options...
munro'sgts-t Posted June 8, 2007 Share Posted June 8, 2007 hey thanx stan every thing turned up undamaged and very well paked i may add had all the coerrect size parts and grub screw so thanx alot ay this was a great but that saved me a few dollars. thanx again Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3168822 Share on other sites More sharing options...
Young GT-R Posted June 19, 2007 Share Posted June 19, 2007 what are the chances of running another buy? going 26/30 within 2-3 months Link to comment https://www.sau.com.au/forums/topic/160608-gb2-jun-spec-crank-collar-oil-restrictors-x2/page/2/#findComment-3188609 Share on other sites More sharing options...
