Hey guys!
Digging up even MORE stuff from my previous ride. This time I have a pair of VDO Dayton HPC1700 MAKE AN OFFER!
These were stripped from my Celica to put other splits in because they were too heavy to stay in the door.
They're both in working order, as I've tested it myself just this evening!
Tweeter/Woofer: ø 25/165 mm
2-way System Impedance: 4 ohm
Max./Nom. Power:
300 Watts/150 Watts
Frequency Response:
45 Hz – 20 kHz
Crossover frequency:
3800 Hz/12 dB
I'm asking for $180 for the lot.. but please! make me an offer!
PM me..
EDIT: "Splits"
Edited by S T A R 3 3
https://www.sau.com.au/forums/topic/160713-fs-2x-vdo-dayton-splits-hpc1700/
  • 5 weeks later...
Hi guys! I've been having internet issues.. where I can't post new topics or PM people on SAU.. its weird.. I can write 'fast replys' but if its over 'x' amount of words, it will just time out..
i cant access myspace, MSN/messenger..
This is the only way I know how to advertise what I have for sale: and yes, THE SPLITS ARE STILL FOR SALE!
Just wanted to give you a heads up before I post this anywhere else.
I'm selling my JVC head unit for $700
I initially bought it for around $1200-1300 a few months ago (February?) and installed it on my 33 and runs like a dream.
Click here for features
  • 1 month later...
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
