hi, does anyone know what type of lights to use in the xenon system for the r34. The lights lense has a sticker on it saying it has been converted to xenon and not to attemt to use any other gas type. so the lights that are advertised with xenon gas are they safe? or will i damage the system ?
and that real annoying beep how in gods earth do you by pass it to shut up?
( plss plss its driving me nuts)
you sure it says converted to xenon not halogen. As for the beep, yeah it pisses me off too
wait yours beeps in reverse. ha ha weird i thought you where talking about when the key is in. Is that standard ?
Edited by nsm034
its got a xenon logo on the lense. so im sure its xenon.
my 34 is auto and when you select the reverse gear it beeps to tell you it in rverse??? so annoying
Just because it says xenon does not mean you have xenon. The lamps would have been replaced to halogen during compliance so I don't think you have xenons. Are ur lights a bright white color and takes a few secs to come on? If so you have xenons...if they are the normal yellowish light, then its been converted to halogens.
if they're converted to halogen it will probably have numbers engraved into the top of the light sort of where the bonnet sits. I'd say your xenons have been chopped out like mine. If so you just get normal h1 halogen bulbs ( i think its h1 , haven't changed them for a while) from autobarn etc. I've heard phillips have good bulbs. The high beam is something diffent but i don't know what it is. Sorry i got a manaul trans so cant help with the beep
that sounds about right its been etched out with a H1 12v/55w serialed into it. The high beam is a tricky one i know never heard of it before.
does anyone out there know how to by pass it and have no sound while reversing ?
You are correct alot of em loose xenons when complianced but mine was left in and alot of others i have talked to theres were also left.
i got the reverse beep aswell.. i think its normal..
yeah its bloody normal.
There is a wire u can cut... apparently if u pull off the plastic covering around your gear selector there will be a wire attached somewhere near the "R" setting u simply cut it.
where is the beep coming from ? Under the dash ? Stick your head where it's beeping and see if it has a beeper/ speaker somewhere and pull the wire going to it
As above... but in saying that I have not cut mine nor look in there as it does bug me when reversing for a while but don't want to damage the interior surround.
so in compliance do they just change the globes or did they change the whole set up? i have xenon, but its been converted back to halogen, want needs to be dont to get it back to the factory xenon? bloody compliance, why cant they just leave stuff alone...
cheers
cheers
Can't simply change back in most cases they cut the wires out making it impossible to fix. Need new headlights basically. Also they usually take the ballasts.
It's a piece of piss to take the surround out mate, look at http://www.r34gtt.net/r34start.html
Hey,
I had a look at that site but couldn't find the bit about the interior console, i've seen that site b4 but didn't realize he modded the inside or had info on it.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
