hey guys, well as says if you are looking at getting a PS3 on launch day pm me. I can give you a better offer through my work than you would normally get. Only thing you have to do is pre-order it with a $100 deposit.
PM me if interested and will talk further.
Cheers.
Mods - put in SA section as only available to Adelaide people.
its a business sinista so its retail price, but i can probly hook up bit of discounts on the console or maybe discount on a accesory or game, so if your interested pm me.
Kye, i wish one could fall off back of the truck, i dont even get given one and im meant to sell and promote them.
retail price on them is $999
Dont really wanna make it open as to where i work, dont want people just coming in saying to anyone that i said i could get them deals, if people are serious about getting one then pm me. I dont have a fixed price, whatever you end up buying i will do my best to mark it down for you. I dont run the shop though so there is only so much i can do. Its not gonna be the saving of a lifetime but to anyone who was already looking at getting one i can help ya save abit more.
even a 5 percent discount is 50 dollars so thats like half of 1 game so i think you should contact skylineguy. if u work at any other retail store and can get more than 5 percent off the marked price of the ps3 on launch contact me...
Edited by Pauly33GTS-t
Well i can tell you the margin is more that 5% on the consoles, but any retail store selling them for less than 999 is not a good idea, you will sell them no matter what by the look of it.
skylineguy19 pm where you work if you like as chances are we are your supplier.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
