BTW Various Performance Parts
Guest INASNT
Ok i been getting all my parts together for my upgrade, but still need a few.
* 6 x 550cc side feed injectors for rb25det, or 6 x 550cc top feed injectors with custom fuel rail.
* Good EBC upto 2 bar resolution.
* Lightened Flywheel (Got 1 in mind but not 100% if i want that 1).
* Power FC with hand controller
* Good streetable clutch able to handle 250+rwkw. (Might be buying steves but he hasent got back to me as yet).
I have a baseline price i want to spend of these items, but if u have any of em for sale name your price and we can negotiate.
https://www.sau.com.au/forums/topic/16082-btw-various-performance-parts/
i paid around $550 for my daiken brass button clutch. dont know if thats suitable. But its pretty easy to change over ya self instead of getting a place to install it for ya. let me know if you are intersted, and talk to the guy a got it off.
well if you are planning on the setup you are after. The full faced single plate, will die very easily, if you are planning to give it some abuse, which i think you will be. after all you dont spend all the money on the mods, and not give it some stick.
Example, guy with the full faced heavy duty organic killed his clutch with just 180rwkw, in 3 months. They are very similar to the stock clutch, with only 25% more clamping pressure. (around 25%).
if u got 250rwkw, your options are brass button, or twin plate. Unless you wanna be blowing clutches up all day long.
brass button is on/ off, but when u think about it. Riding any clutch, does cause damage. And once you get used to the brass button they are meant to be pretty damn good.
But then you got the twin plate, and then thats just goes to another level. and then it goes into the $1000 plus region.
find a friend who has a brass button clutch, or someone off the forums, and see how it is.
you know you cant go off what people say as gossiple. Only way to really know if it suits, is to try for yourself.
laters
Guest INASNT
laters
I have driven once about 1 year ago my friends r33 with a brass button clutch and i kept stalling it! I drive my car to and from work in peak hr traffic and sometimes behind trams and crap so it would be a ball breaker to drive it with the button clutch! A 9 puck single is capable of handling the power like whatisname is using with 260rwkw and matlowth with 300rwkw is using a daken extreme also without any problems
    • Yeah it is always worth testing and balancing actuators out of the box, just set the pressure regulator on a compressor very low (eg 5 psi) and increase it slowly to see when they both move.....unfortunately while you may be able to adjust the length of the actuator rod to minimise any difference, the actual pressure they move from is not adjustable so you need a well matched pair. And yes, the VCAM is probably contributing; the earlier in the rev range they come on boost and the slower the revs build (I think your demo was in 5th), the more you notice it.  Driving at WOT through 1st, 2nd, 3rd etc you will probably never hear it as any shuffling starts and is over super quickly
    • oh they were with that motor, you need to remove the engine to change the spark plugs (don't have to, but it does make it easier)
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
