I have a '93 model R33 GTS-t 4 door 5-speed if you're interested.
I imported it myself.
It has 71,000km on the clock, is 99% standard (just ricey metal pedals & a CD stacker) & runs beautifully.
I know you're looking for an R32, not R33, but let me know if you're interested & we can talk prices.
Primo,
I put a post up recently in regards to this, because according to what I found it's still eligible - it's just a matter of finding a compliancer with RAWS certification.
Here's the link... If you actually click on the number in the left-hand column, it shows which versions of each car are eligible (unless I'm reading it wrong).
I've emailed you in the past regarding this, but it was way before RAWS came into full effect, so if you can find out more I'd also be keen to hear about it too!
Cheers,
Nick
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
