hey all can you tell me whats most likely to produce metal shavings from around the cas/cam gear area on the right hand side when the car is running? am i looking at a wrecked bearing or something wrong with cas? car makes a funny bearing knock and whine that is coming from under the cas somewhere, not actually in the motor but (phew)
cheers Acea
Edited by 84ace
Dont start it again!!
Im betting youve taken the timing cover off and have exposed cam gears?
The shavings are from the nose of the exhaust cam grinding into the back of the CAS. Akin to putting the CAS on a lathe
This happens because the clearance that the timing cover provided has been taken away. Now theres no room for both to spin in harmony
You need a spacer plate cut from some alloy or something, or just put the timing cover back on
The pin from the CAS with the half-moon end might have snapped off already, plus the heat that is generated when the shavings go everywhere, means the CAS might not have much life left unless you dont start the engine again!
shit hey.
i'd say that's what it is, we do have the timing covers off. i hadn't even considered that the cas bolts onto the top timing cover, which is Xmm thick.
what are the chances anything important is shagged? i've got a spare cas if that's the only thing that's likely to have been shot. the half-moon lug thingo inside the cas shaft is still intact on the one still in the car.
thanks for the replies fellas
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
