I have some tomei cams in my GTR that i bought not long ago, put it on the dyno quickly and got 70 more kw out of it (yes they were set up that bad). Makes 240 rwkw at 14 psi (steel wheeled turbos but unsure what is actually done, ie bigger wheels)
When you buy the tomei cams new do they come with a degree card to dial in the cams properly? If so does anyone have it so i can do it, if not if it just trial and error?
Cheers
Edited by GTR1993
https://www.sau.com.au/forums/topic/161093-tomei-poncams-degree-card/
I have some tomei cams in my GTR that i bought not long ago, put it on the dyno quickly and got 70 more kw out of it (yes they were set up that bad). Makes 240 rwkw at 14 psi (steel wheeled turbos but unsude what is actually done, ie bigger wheels)
Cheers
If you mean the 9.15 lift PONCAMS....they are stated that a 0 intake and 0 exhaust is best,for stock motor.
You have after market turbo's so -2 or -3 on intake and -4 to -6 on exhaust is the area I
would be experimenting on in the tune.
Good luck....A 5 to 6 hour tune is required to get them spot on.
yeah but zero on the gears is not often zero on the cams, HKS especially need dialling in to get a "real" zero. some supra ones i used on this car a few years back were ~4 degrees out.
Edited by URAS
yea and because the motor is rebuilt with a thicker head gasket, along witht he deck may or may not have been decked can also change where true 0 is, i threw it on the dyno and got some good gains and got the mixtures where they needed to be, i think the exhaust cam could still be holding in too much exhaust gasses (or the exhaust was too restrictive i cant rember if i still had the minature cat converter in it) as it didnt want to take much ignition timing.
What timing can you put into these 26s? I was suprised as mine seems to be decompressed (flat 125 psi across all 6) and didnt like alot of timing.
Nah i dont mean the wheel, i mean at what crank angle should the inlet/exhaust be opening the valve 20 thou, or how ever they want to rate it as.
On some wade cam specs i got here it says when they are open 50 thou so you can get a decent starting point, then go from there.
Edited by GTR1993
When you install cams...you need to put them in at 0 degree..I think they call it drop centre.
There is lots of talk about this on the Forum...do a search.
You then dial the cam gears to adjust the cams.
Am I reading you guys right here.
More than likely the Supra cams or cam gears were installed incorrectly....it is easy to make a mistake .
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
