Hi guys,
I was wondering if anyone knows the technicality for serving a summons.
Basicly, SAPOL is trying to charge me for speed dangerous driving.
On the day the officer pulled me over, he wasnt able to pinpoint my speed.
He claims that I was travelling at an excessive speed because he only caught up to me after driving at high speeds himself.
He didnt give me a fine on the day but decided to summon me to court 2 weeks later.
The problem was that I moved to Japan since then and it had been slightly over 2 years. They have been coming over to my parents home but unable to give me the summons.
My question for those who know, is there a time limit for them to charge me and if not, what would happen if this continues?
Thanks for reading and replying in advance.
https://www.sau.com.au/forums/topic/161207-please-advice-legal-question/
Hi guys,
Not 100% sure about the time limit, but they do have to put the summons in your hand personally otherwise it is not legal.
Sorry i know that is not much help.
Arnt they supposed to have proof of the speed travelled? Ie show u on the radar what speed u were doing, and report it then and there?
Might be time to find a good lawyer etc...
Thats what i thought, they have to have proof that you were doing those speeds...Was there one police officer or two in the car?? I got done for a similar thing, because there were 2 police officers in the car, 2 SAPOL v's one import driver... wonder which side the judge would take...
They can issue summons without you being there, they issued my summons to my mother whilst i was at work whilst i was living at home....Unless i got stooged on that account!
sapol read this site. best get this off here id say and if anyone was to give him advice, do so via pm. my advice to you is you didnt remember now did you? you were speeding? couldnt have been you... get my drift *wink wink *nudge nudge.
well normally when you don't rock up to court for a long time they'll issue a warrant out for you're arrest! unless you're a murderer you won't be on top of the list! happened to a mate who was up for drink driving charges and when he didn't rock up for a while he was pulled over for speeding once and when the cops checked up on him he was arrested for the warrants or some shit! well it was something like that
they have 9 months to put a warrant in your hand if they dont then you can contest it and ask them why they havent tried harder to find you and summons you if it was such a big deal, the missus nearly got away with it when she got impounded and that what the cops told her too that they have 9 months..
and also if they dont show you the radar gun with your speed they cant fine or prove what speed you were doing
Edited by Import S13
WOW - an old school member I haven't heard from in ages! How are you doing mate?
I got a summons for a driving issue a while back and had my day in court etc etc. My mate who earned the same fine and was supposed to get a summons at the same time wasn't home much (around the time I got my summons) and they stopped trying to give it to him. That was nearly a year ago - they knocked on his door twice and failed (neighbours told him), and that was it - he hasn't heard back about it.
But yes, I have also heard that they just turn it into a warrant, so when you get pulled over for some menial thing, they slap bracelets on you and take you away.
I would be fearful about coming back into Australia N/A and would seek legal advice before even trying just in case (if you are ever coming back).
Thanks for all the replies guys!
Im not too concerned about the fine or the loss of licence. The fines in Adelaide are peanuts compared to Tokyo. So consider yourseves lucky guys!! :wave: Its the nuisance for my parents from the police visits that worries me.
I think I can argue the charge because there was only 1 officer and he didnt keep a constant distance to calculate my speed. I believe this is what the law requires, but then again, no one ever knows with law right!
Anyway, if anyone has a definate answer, please let me know!
Whats up Nightcrawler! Hows the 34?
yeah it's good mate - loving life! Sold the S15, which sucks :wave: , but on to different things now, so the Skyline keeps me entertained. Hope life is treating you well in Tokyo!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
