I have searched the forum and they do fit apparently to the GTST rails but why do you not see many R32 seats into a 33? Is there a reason? Do they 32s seats look bad in real life? they uncomfortable? or what? im looking to replace my series 2 seats and they GTR seats look more sporty and they arent a defect. And the GTR seats from the 33 and 34 are out of my price range...
Whats your thoughts?
Am i missing something in putting R32 GTR seats in a GTST R33? cos not many people have done it...?
Edited by Adz2332
https://www.sau.com.au/forums/topic/161325-r32-gtr-seats-into-a-r33-gtst/
It is not often done as R32 GTR seats are hard to find in good condition. Also, its like a step backwards. You are putting older seats in a newer car. Go figure!
I would be spending the extra money and looking at a set of R33 GTR seats or even genuine aftermarket Sparco or Recaro's.
I know of two people who had them in there 33's, they where great!
You can't really notice they are out of a differant car either, the grays blend in well
If you can find a decent set then its a great upgrade
give a bit more time..save a bit more $ and get the R34 GTR's seats
you'll love them, imho
hah yer that wouldbe nice but i dont reali wanna blow a couple grand on seats haha. just something that looks and feels more sporty will do just fine! lol
I have a R33 gtst S1 that i have just secured a drivers R32gtr seat for, my mate has a set in his 33 they look and feel good!! good alt to spending heaps $$$$ ,now all i need is to secure a passenger side seat!! :)
Edited by madaz R33
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
