Hey all,
I have a set of PHAT dished alloys from Japan that I no longer have a use for so they're up for sale. They're in fantastic condition - here are the details;
Please only enquire if you are serious;
For sale: Kayzer 18in alloys. Fronts are 18x10J, rear 18x11.5J with offsets of +2 and -17 respectively. In true Jap form they have stretched 235 and 265 boots with enough tread to get around on for a while...
Item Condition: Awesome condition - I just had all the minor marks all polished out and cleaned up, almost look like new
Price and price conditions: $2300
Extra Info: As above, they've just been polished and restored - all centre caps are there, very tough looking wheel and hard to get in these sizes. They look heavy but are surprisingly lightweight - I'll throw them on the scales and let y'all know tomorrow.
Pictures: Below
Contact Details: PM
Delivery & Conditions of Delivery: We'll sort it out...
Cheers,
Chris
Edited by YSR020
Bump for pics!
Also, upon closer inspection the rear tyres are ok for minimal use, probably not road worthy, the fronts are Rev Spec tyres and are quite healthy, they have about 75% tread left.
Also, for those concerned about the weight (as I was initially!) the fronts weigh 22.5kg ea with tyres. By comparison my R32 GTR wheel & tyre weighs 20.2kg...not bad at all IMHO.
Any queries via PM - please don't waste my time...seem to be quite a rare wheel - I've never seen another set of these at all, let alone for sale!
Cheers,
Chris
Nah man, but you're more than welcome to come 'round and throw them under yours.
Also - sorry if I mislead you to think I have a 32GTR cos' I have a set of 32GTR wheels, they're off my Silvia... :)
mate i'll trade for my wheels if your intrested
Sorry mate - I have no use for wheels this wide anymore...going sleeper... :laugh:
got pics of em on ur silvia?... what guard mods...?
Nah I don't sorry mate...you'll need a widebodt conversion, which means front and rear guards of course...anyone game enough? :rant:
You interested in trade plus cash your way? I have 2 different sets of 17 inch rims that I could offer...
WED Sport 17inch Rims
I also have a set of Koya Driftek rims that are vertually brand new... See the attached picture!
Thanks,
Robbie
Hey Robbie - I'm really interested in selling them outright sorry...I already have new wheels for my new car... :D
Ironically enough, if I had to throw these wheels under something it would be a white 33 Series II...tough!
Free bump for the tough Jap dishes!
Ok guys - I've had a few people enquire as to how they'd fit on they're car...so to help all you peeps size your guards up, here are the dimensions;
145mm front
185mm rear
Those measurements are from the back of the centre of the wheel, where the bolt holes are (the part that sits flush with your hubs) to the outer edge of the wheel. So to see if they stick out you'll have to take a wheel off, measure either of the above distances from your hub to the outer and run a string line...that'll give you an indication of where they'd sit.
Also needless to say, they're 5x114.3 stud pattern...!
Cheers,
Chris
Edited by YSR020
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drive beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
