recently adjusted my coilovers and lowered them but i think one side is higher than the other. I counted the coils and everything and marked off where i should lower it to but it still seems crooked. Is there any why to get it perfect? or is there a way to measure the height of each?
help pleeeease!
thanks!
https://www.sau.com.au/forums/topic/161410-uneven-lowering/
Dont forget if you've got a big ass sub hangin around in the boot it will be off
Ussally the car is set at different heights anyways.. Nose slightly up tail slightly lower.. R34 optimum setup is meant to be 350 front 340 rear from memory (my memory often serves me wrong)
https://www.sau.com.au/forums/topic/161410-uneven-lowering/#findComment-2999227
To summerise:
- Make sure car is on level/flat ground.
- Measure height from centre of wheel to arch
- Ideal height for handling is: 350mm @ front, 340mm @ rear
- 1mm adj on coil = 1mm adj in height.
- After each adjustment go for a drive, swerving from side to side, to try and seattle the shocks b4 re-measuring.
- After a few days, re-check the height as the coil-overs would have deffinately settled
https://www.sau.com.au/forums/topic/161410-uneven-lowering/#findComment-2999360
The movement/leverage ratios are 1:1 for skylines as the spring/shock unit is connected to the hub and moves vertically (not in an arc or on an angle).
So 5mm movement of spring seat/lower bracket will raise/lower the car 5mm.
Besides that, Al's on the money.
Edited by salad
https://www.sau.com.au/forums/topic/161410-uneven-lowering/#findComment-2999439
Have edited my posts :wave:
As i stated i wasn't sure as i have not yet adjusted the height of my own suspension; will be fitting new Teins and adjusting heights in the next few weeks >_<
cool thanks, i have Cusco fully adjustable i love the feel of after market coils on the road
https://www.sau.com.au/forums/topic/161410-uneven-lowering/#findComment-3001563
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
