Im selling my car and moving on for a while, as im over cars and all the headaches.
Details as follows:
1990 R32 GTS-t Mspec
RB20 motor with 70,000ks
strong RB20 gearbox with C's short shift kit
TD-06 20g L2 turbo kit comes with lines manifold, 3" dump, 47mm external gate with screamer fitted. (Full GReddy kit)
HYBRID GT FMIC with GReddy hotpipe
Just Jap oil cooler and relocation kit
APEXI power intake
NISMO dash
BRIDE fixed back driver seat (standard passangers seat)
OMORI oil pressure & temp, water temp and exhaust gauges
GReddy boost gauge
2 way
TEIN shocks and springs
16" RAYS Syver rims with legal rubber
front and rear strut brace
Cyclops Alarm with 2 point immobiliser and turbo timer
PLUS OTHERS
Interior is in A1 condition and has car has working A/C.
Paint is deep blue and is in great condition, the car has no rust or dents and is perfectly straight.
Things that need looking at:
desperate need of wash and polish
Hole in left reverse light
$14500 as is or $16800 with extra's
Car is out of rego but if its a local sale can arrange a AIS inspection so its ready to be registered again.
Grab yourself a bargain today as this car is perfect for a daily, track weapon or drift machine.
PM or reply for more details.
Cheers GMB
https://www.sau.com.au/forums/topic/161416-r32-gts-t-td-06-equiped/
Your car looks mint mate except i think your being a bit optimistic with your price.
9.5k for a car that needs an engine rebuild is a bit dear.
Anyway good luck with the sale.
Different strokes for different folks old kid.
$500 for another stock 20 or rebuild for 1k and you have one very well set up car that is the perfect base for track, drift, drag or the perfect daily sleeper :wave:
The car was pushing 200+rwk out of a stock 20 on 14psi and HAS alot more potential so think what it can do with a freshen up ;)
Find me another car around the same price with the same gear that has the same amount of potential with no rust or dents???
If i had the time or money i would hold onto it myself but i dont hence the sale.
The price is negotiable and for everything that the car comes with i think its reasonably price :unsure:
Cheers GMB
There is a RB20 with 75,000ks and in exceptionally great health that will be in Tasmania in the next few weeks (currently in Victoria)
$1000 for the motor and its ready to drop straight into the car for one hell of a daily :wave:
Open to offers on the car :unsure:
GMB
Got any engine bay pics?
How much would it cost to send a car like this to Sydney?
Here is an old engine bay pic, will get some new ones up ASAP.
Not 100% sure costs but i would say around $500ish to send to Sydney... If you give me your postcode i can find out if you like???
Cheers GMB
  • 3 weeks later...
PM's replied.
To the people that enquired about freight to Melbourne, it would be cheaper for me to drive it up and put it on the spirit and you meet it on the other side :)
Cheers GMB
  • 3 months later...
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
