hey guys. just wanted to know what to set my knock sensor to.,
uras, or whover.
how do i set it up.
atm the jumper for it is set to 1-2. and in parameters im using the air intake temp/knock sensor 2 with it set to resonate and 7.02.
is this cool??
non res and around 7khz works well.
  • Replies 765
Trent, how would you diagnose knock with EMU? As long as its above 1% its all knock ? I forgot what knock is there in. % or not.
How far would you usually go with tuning ? Under 30, under 10 or fight knock until its below 0 threshold ?
Thanks!
ok i have finished my car and my mechanic tells me that i need to get it tuned.
WHERE THE F#%K CAN I GET IT TUNED IN BRISSIE AND GOLDY AREA for a good price???
Try Godzilla - I hear he does very good work!!
^^ yeah but ive never had issues unless its wired wrong. try updating EMU and software from the greddy japan site.
Thanks for the reply. The wiring looks ok (to me), the car runs ok, but the error log and flashing red light on the EMU continues. My software on the laptop is v2.16, I'll check what is loaded on the EMU when connected, but I think it's up to date.
I'll PM you a config printout (pdf), if you wouldn't mind having a quick look.
cheers.
Thanks!
i always use my GIZZMO K-Mon to monitor knock as a back up but the EMU shows actual knock if you get any spike at all it is generally knock.
thanks very much pear...would they be in yellow pages?
any contact info?
they the ones on ashmore rd or ingelston rd?
http://www.godzillamotorsport.com/
addr and contact details are on their site. -- ingelston Rd
I haven't been there myself, but have heard good comments from other SAUQld members.
ask for Mark -- or send him a pm 'markr34gtr' http://www.skylinesaustralia.com/forums/m4681.html
good luck, & keep us posted!!
Pear
Check that the signals going from the ignition relate to the right ones coming out
mine threw up that error and a red light when the channels didnt match to the igniter no. (3,4&5 were not matched up properly)
I changed them and the error messages went away
Hi Haines, thanks for the reply.
I've had another look at the wiring, visual inspection only, but it looks ok.
Next step is to get it tested.
I've attached pics of wiring and EMU setup. If anyone what to comment, please feel free
Cheers
Pic___Ign_Wiring01pdf.pdf
ScreenShots_of_Setup01.pdf
Hey guys, sorry to ask this one as I dont know if its been covered (dont have time to read 26 pages!).
The software that can be bought for the Emanage, Nengun says its in japanese, Is that just the instructions or is the program in japanesE?
Haha! I got the N-4 harness. Nice little piece of plastic ))
Swapped Ne and G, then Disconnected A and Ar1 hooked them up with other 2 free connectors.
Now I got no Water temp. Will be a bitch to find out which one is water temp now.
Btw, from factory N-4 harness comes wired with 2 knock sensors or air inlet temp and water temp ?
Thanks !
Ok. Swapping Ne/G was a bad Idea !!! I put them back, like greddy default and got my timing control/datalog back. Before it was 111deg. everywhere.
I did a few power runs like that and got massive missfire in 160km/h area.
The knock sensor 1/water temp should be left along, like greddy n-4. It will read water temp, not knock. And remove intake air temp and swap it with another purple/yellow wire. And u will get knock 2 working.
Now the funny part.
RB20DET inj. pin out order is a bit different to rb25/rb26 !
RB26 goes like #5 #6 #4, and rb20det goes like #5 #4 #6. I just figured that out. And now, its 3.30 am and I'm thinking how to swap those wires. Any good ideas ?
Other issues I've discovered. Need to adjust the TPS in EMU. Otherwise u won't have good idle and idle afr/s and no map trace.
Consult came up with TPS error when I didn't calibrate the TPS in EMU. After calibration this error went away.
Before swapping Ne/G back to the greddy default order G/Ne. (Not Ne/G), EMU was attacking me with ign. channel errors. all 6 of them.
Now I got no Errors in EMU.
But I still got the 21/ign. circuit error in ecu through consult.
Haven't got a chance to take a car for a datalog run after that.
Can post some datalogs of what was it like before.
I'm really having a hard time with making an EMU work )) Why me ? )))) lol.
I thought n-4 harness with magically solve all my problems. But it damn didn't do it right away or yet. hehe.
Hope for some input here.
hi there i wonder if anyone can tell me where i am going wrong gor r33 gtst 1995 i have wirried emu but i keep getting these error shortly after car is running
30:0441-0005[incorrect 1CH ignition input signal]
31:0442-0004[incorrect 2CH ignition input signal]
32:0443-0006[incorrect 3CH ignition input signal]
33:0444-0001[incorrect 4CH ignition input signal]
34:0445-0003[incorrect 5CH ignition input signal]
35:0446-0002[incorrect 6CH ignition input signal]
ii have checked wirring and is ok i have swaped jumpers over but still get the same fault do i ahve to set jumper to 12v or 5 volt for this car
would greatly apreciate it
ok i sorted that error out but what voltage do i run 12 or 5
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
